95 STS parking brake release switch
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 STS parking brake release switch in Past Cadillac Vehicle Discussion; Im trying to replace my parking break release switch but i cannot figure out where it is located. If someone ...
    chewy_likea_nut is offline Cadillac Owners Member
    Automobile(s): 1995 STS
    Nov 2012
    46
    Im trying to replace my parking break release switch but i cannot figure out where it is located. If someone could put a diagram up or point me in right direction that would be awesome.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Switch? You mean the auto release mechanism? Vacuum diaphragm?
    I don't have a diagram, but everything's attached to the pedal assembly under the dash.
    Nov 2012
    46
    Its a
    Duralast/Parking Brake Release Switch
    This product is a fit for your:
    1995 Cadillac Seville STS 4.6L SFI DOHC HO 8cyl
    Part Number: SW2090
    got it from auto zone because my car was saying break switch problem.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,489
    Re: 95 seville sts parking break release switch
    Quote Originally Posted by chewy_likea_nut View Post
    Its a
    Part Number: SW2090
    FIRST you should figure out WHICH brake switch needs to be replaced -
    there are two switches on the regular brake pedal -
    and one for the parking brake -
    Nov 2012
    46
    How do i get to them?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Which one you have problems with the parking brake switch (as in the PARKING brake light stay on, or never goes off) or is the regular brake switch (possible issues brake lights not turning on or off, ABS code "Brakes applied while brake signal was not on")?
    Regular brake switch is actually 2 switches one for ABS and one for brake lights and is(are) located above the brake pedal.
    The parking brake switch is also located in the area above the parking brake pedal (part of the release mechanism).
    Is amazing how you know the part you need yet you are not sure what is the problem…
    68
    82,083
    Re: 95 STS parking brake release switch
    #15
  10. Remove Advertisements
