B112 - A/C Low Side Temperature Circuit Problem [A/C Clutch]
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, B112 - A/C Low Side Temperature Circuit Problem [A/C Clutch] in Past Cadillac Vehicle Discussion; Hello - I just got a 1988 Eldorado from Ebay. When the car starts, the DIC displays "A/C Sensor Fault". ...
    RMarek69 is offline Cadillac Owners Member
    Automobile(s): 1993 Allante, 1988 Eldorado
    Sep 2013
    Arlington, VA
    47
    7
    Hello -
    I just got a 1988 Eldorado from Ebay. When the car starts, the DIC displays "A/C Sensor Fault". I followed the procedure to display the codes, and the only current one is "B112 ......................... A/C Low Side Temperature Circuit Problem [A/C Clutch]".
    Can someone help me figure out what this means? I understand from the previous owner that the compressor has been replaced recently and that there is a sensor that is bad. Any ideas?
    When I search the forum, most of the results contain a list of all codes, I just need to address this specific one. Any assistance is appreciated.
    Thank you,
    Robert
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Re: B112 ......................... A/C Low Side Temperature Circuit Problem [A/C Clu
    I believe there are two freon temperature sensors - thermistors -
    one near the orifice tube - low side -
    and one near the compressor - high side -
    the one near the orifice tube gets destroyed
    if the orifice tube is put in backwards -
    or the wrong - longer - orifice tube is installed -
    there was also an issue about getting this error on systems that were converted -
    from the original R12 - to 134A -
    there were two "tricks" -
    one was to use the BLUE - Ford orifice tube -
    the other was to install a 2k resistor on the low side thermistor - temp sensor -
    Sep 2013
    Arlington, VA
    47
    7
    Thank you for your reply. This is all way over my head so I will have to bring it in somewhere to have it looked it. I was hoping I could just switch out some sensor. Hopefully it will not cost too much!
    Robert
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    Quote Originally Posted by RMarek69 View Post
    Robert
    it is also WAY OVER THE HEADS of MOST shops -
    where ever you take - ASK IN ADVANCE -
    if they ever converted old Cadillacs from R12 to 134a -
    if they answer YES -
    ask them if they know about the resistor for the freon temp sensor -
    I say this because MOST shops DO NOT -
    and will not be able to get your AC to work -
    and still try to charge you for their time spent -
    Sep 2013
    Arlington, VA
    47
    7
    From what I understand it is still R12. I think the previous owner said that it was converted to R134, but then converted back to R12..I'm not sure why that would have happened, but I think I also read somewhere that these Cadillac's can not be converted to R134 because the sensors do not work.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    my point exactly -
    like I said - be sure to ask questions before you take it in -
  9. Remove Advertisements
