Should the manifold overpressure relieve valve be hissing?
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, Should the manifold overpressure relieve valve be hissing? in Past Cadillac Vehicle Discussion; Greets, Like the title says, should the manifold overpressure relieve valve be hissing? After changing out a starter motor my ...
    DJSG3 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Deville DTS
    Dec 2005
    Joisey
    252
    Greets,
    Like the title says, should the manifold overpressure relieve valve be hissing? After changing out a starter motor my car developed an idle problem and after testing pretty much everything else involved the only thing I've noticed is a hissing sound coming from that area. Using a tube to my ear to isolate the sound, its only present when I'm at the front side and center of the manifold. If I move to either corner sound goes away.
    DJSG3
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,480
    Re: Should the manifold overpressure relieve valve be hissing?
    NO -
    you could use carb cleaner to verify/find a vacuum leak -
    with the engine running - spray it around the suspect area -
    if the idle speed changes - you found a leak -
    68
    82,064
    If it's hissing, it's not seating properly and you have a vacuum leak. You may be able to clean and reseat the seal.
    Dec 2005
    Joisey
    252
    Greets,
    Turned out not to be the valve but the piece the valve sits in. It apparently loosened when disconnecting/reconnecting that vacuum line right below the fuel rail. Turned it as far as the rail would permit and then put some silicone caulk along the screw edge of the whole assembly, pushed it in with a putty knife, let it sit for 12 hours and then reassembled. Idle is now back to normal.
    DJSG3
  7. Remove Advertisements
