2001 STS A/C air transfer actuator
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 STS A/C air transfer actuator in Past Cadillac Vehicle Discussion; how to tell which actuator is bad i have no air out of vents only on floor and some times ...
    123jimmy is offline Cadillac Owners Member
    Automobile(s): 2001 sts
    Sep 2013
    65
    1
    how to tell which actuator is bad i have no air out of vents only on floor and some times defroster
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Wrong forum.
    That would be the mode door actuator, assuming the actuator itself is the problem.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,566
    Re: 2001 STS A/C air transfer actuator
    Let's move this from the "DTS" forum down to Seville.
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,263
    Quote Originally Posted by 123jimmy View Post
    like Moistcabage said -
    the MODE DOOR actuator changes WHERE the air comes from -
    and if it is defective - it should set a code -
    so - FIRST - check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
  6. Remove Advertisements
