Sputtering 4.9
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Cadillac Seville / Cadillac Eldorado Forum Discussion, Sputtering 4.9 in Past Cadillac Vehicle Discussion; Before i ring my mechanic.... Wondering if anyone here can help. 1991 ETC 4.9 ..Mild Sputtering on acceleration. Seems to ...
    zentrade is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 1993 Deville 4.9, 1991 Eldorado Touring Coupe
    Dec 2006
    370
    Sputtering 4.9
    Before i ring my mechanic.... Wondering if anyone here can help. 1991 ETC 4.9 ..Mild Sputtering on acceleration. Seems to have a rich mix also but wondering if thats the ECM adjusting for a lean condition. 65k miles, Otherwise running fine. Any common place to start looking? (vacuum leak etc.) .....cleaned out the throttle body already. Car was off road a long time too. Thanks!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Have you pulled the codes?
    How old are the plugs wires cap and rotor?
    Dec 2006
    370
    Re: Sputtering 4.9
    No codes related to engine management, Just the active suspension sensors. Plugs and wires as well as cap replaced and a fuel filter recently
    Sep 2010
    East Boston MA.
    29
    26,323
    '91's don't have active suspension, just ELC (Electronic Level Control).
    I would check the catalytic converter. The FPR might be worth checking, but that shouldn't cause problems when accelerating.
    69
    82,383
    Re: Sputtering 4.9
    Quote Originally Posted by zentrade View Post
    Does that include the rotor?
    Dec 2006
    370
    Re: Sputtering 4.9
    Yes, Rotor changed as well
    Dec 2006
    370
    Re: Sputtering 4.9
    Ok i went out and checked again for codes, Voila...a new one is displayed E012 No distributor signal
    Sep 2010
    East Boston MA.
    29
    26,323
    Start by checking the wiring to the distributor, and the connections to the ICM inside the distributor. If that checks out, have the ICM tested.
    Dec 2006
    370
    Re: Sputtering 4.9
    Thanks, Thats my next step....was a bit too late to start working on it last night....my saturday project now
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: Sputtering 4.9
    '91's have CCR, Computer Command Ride...a form of active suspension...
    Sep 2010
    East Boston MA.
    29
    26,323
    I know Devilles, Fleetwoods and Allantes had it, I didn't think Sevilles/Eldorados had it.
    Feb 2009
    Jacksonville, FL
    1,023
    Re: Sputtering 4.9
    Yeah, my '91 Eldorado had it...
    Dec 2006
    370
    Re: Sputtering 4.9
    So i got as far as getting the dist. cap off before the "crew" here decided my day would be spent elsewhere. Just got a chance to sit and research and was just wondering if maybe i shouldn`t even bother testing ICM since its a less than $20 part and just replace anyway since the car is 22 yrs old. For that matter , I also wonder if i should just replace Hall Effect Sensor while im there....although the HES is more costly. No loose wires, everything looks good otherwise so i dont know what else can be sending the E012 no distributor signal trouble code and causing the sputtering. I am only assuming that trouble code is why the car is not running as good as it should be.
  16. #14
    Feb 2009
    Jacksonville, FL
    1,023
    Re: Sputtering 4.9
    Hall Effect = E012
  17. #15
    Dec 2006
    370
    Re: Sputtering 4.9
    Ok..Thats what i was figuring Thanks!
  18. Remove Advertisements
