Sputtering 4.9 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Cadillac Seville / Cadillac Eldorado Forum Discussion, Sputtering 4.9 in Past Cadillac Vehicle Discussion; ...actually noticed that Hall Effect (aka Cam Position Sensor) is E041...But i am not getting that code but thinking to ...
  1. #16
    zentrade is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 1993 Deville 4.9, 1991 Eldorado Touring Coupe
    Dec 2006
    370
    Re: Sputtering 4.9
    ...actually noticed that Hall Effect (aka Cam Position Sensor) is E041...But i am not getting that code but thinking to replace anyway
  2. #17
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: Sputtering 4.9
    That code throws when the hall effect completely burns up. Had the same problem and kept getting E012 no matter what I replaced....FINALLY got the hall effect and voila, the problem went away.
    Six months later, had the same problem...pulled the hall effect...looked really close to it and found one of the tiny resistors was starting to blacken, i.e. intermittent running issues.
    The only other thing that runs in conjunction with the hall effect is the ICM. Testing those at a store is useless. They test them in series, yet the ICM works off of ground...they never test them to ground and therefore they almost always test good...then you go home and put it back on and wonder why the motor stills runs like crap....
  3. #18
    Dec 2006
    370
    Re: Sputtering 4.9
    Ok thanks! good to know..Gonna go ahead and replace the Hall Sensor and ICM...
