Blower Motor Replacement Issues
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, Blower Motor Replacement Issues in Past Cadillac Vehicle Discussion; I'm a new member, I've got a '97 Eldorado. Blower Motor not working, so pulled it. As you know it's ...
    Robert97 is offline Cadillac Owners Member
    Automobile(s): 1997 Eldorado
    Sep 2013
    58
    3
    I'm a new member, I've got a '97 Eldorado. Blower Motor not working, so pulled it. As you know it's a Very tight space between the fire wall and engine. I ended up taking the blower "apart" in place (the firewall mount/connector comes apart from the motor and the cage) and squeezed each piece out individually. Unfortunately the only replacements I've found are one piece units only (cage, motor and mount flange all one piece) and it won't squeeze into the tight approach.
    So I thought I'd look into fixing the old blower motor instead. I Cleaned the contacts and copper etc and tested it. It will make maybe 1/8 turn then stop and then start and hesitate etc. So...questions: 1) Any suggestions on what to do to test and make a repair to the "old" unit since it fits and/or 2) Any suggestions on how to get the replacement unit to fit? I've removed the plastic engine cover, plugs wires, other leads and cables in the way. Any other tricks? By the way, the replacement unit runs great when you connect it. Changes speed well, no hesitation etc. Just can't get it in place. Thanks Robert
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,263
    Re: Blower Motor Replacement Issues
    disconnect the dog-bone engine strut -
    and you should be able to pull the motor forward enough to slip the new blower into place -
    some have used a turnbuckle where the strut was -
    some have used a 2X4 CAREFULLY PLACED - with an assistant -
    if you crack the cage while installing the fan - STOP -
    you MUST either replace the cage - or the entire blower -
    and glueing it back together WILL NOT WORK -
    the extra glue WILL throw the balance way off -
    and the entire dash will vibrate - until the blower tears itself apart -
    WATCH YOUR FINGERS -
    68
    81,755
  5. #4
    zek4964 is offline Cadillac Owners Fanatic
    Automobile(s): 08 cts 68k, 07 STS-V 15K, 97 Sts 160k
    Jun 2010
    Rochelle IL
    302
    If you search my user name zek4964 you should find a nice write up on what I did to get the blower motor into place. In short, I removed the old one and assembled the new one in place in the fire wall. You can get it into place without pulling the engine forward. I used an old one out of a deville and I did not have force the engine foreword I was able to take the motor apart and install the parts in place. But I am pretty sure the cage has to come off and the steel plate with the connector on it as well.
    I have been told the NEW ones will not fit and the motor has to be pulled forward to install.
  6. #5
    LloydCFerguson is offline Cadillac Owners Member
    Automobile(s): 1997 ETC, 2002 STS
    Mar 2012
    Glendale, CA
    44
    I fought with my '97 ETC, got the old one out but couldn't get the new one in until I dropped the front of the cradle a few inches using my floor jack and jack stands. the biggest PITA was crawling under the car to disconnect the exhaust system (4 bolts)
  7. #6
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    I dropped front of subframe to help rear valve cover swap. Did not touch exhaust. Don't follow why exhaust would need to be moved or unhooked to tilt subframe forward
  8. #7
    Mar 2012
    Glendale, CA
    44
    It was either the FSM or something I saw on line that said that was the correct procedure. I assumed it had something to do with the exhaust manifold wanting to rotate slightly as the front of the engine dropped and putting stress on the joint.
  9. #8
    ronluh is offline Cadillac Owners Member
    Automobile(s): Black on Black 2001 esc
    Nov 2011
    SanDiego
    29
    72
    Remove rear valve cover with swivel socket..... no sub frame drop on eldo's.....
  10. #9
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    Quote Originally Posted by ronluh View Post
    Which is what i did
  11. #10
    pocketpared is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Eldorado
    May 2009
    200
    I don't know about your model but on my 92 Eldo there were 2 lines molded into the upper sides of the rubber shroud surrounding the blower assembly with the words "Cut Here" molded in. When you cut along those lines it was much easier to get the blower unit up and out and down and in and when you're done there's almost no gap and I didn't notice any drop off in air flow when I was done.
  12. #11
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,263
    Quote Originally Posted by pocketpared View Post
    completely different car - and engine -
  13. Remove Advertisements
