Trouble getting fuel to go into tank - '98 STS
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Trouble getting fuel to go into tank - '98 STS in Past Cadillac Vehicle Discussion; Any idea why the fuel shoots back out the filler neck when attempting to fill at gasoline station. Get about ...
    surrfman is offline Cadillac Owners Member
    Automobile(s): 2007 DTS Performance Edition
    Aug 2013
    59
    46
    Any idea why the fuel shoots back out the filler neck when attempting to fill at gasoline station. Get about half a gallon in before the fuel literaly comes gushing back out. Tried throttling the pump nozzle, doesn'rt seem to help much. Is there a vent tube blocked or crushed maybe? Only a pressure feed and return from fuel pump in-tank module. Is there a vent that is hosed to a vent solenoid that might be stuck shut? Get no codes of any kind.
    Thanks,
    Timmy C
    69
    82,180
    Re: Trouble getting fuel to go into tank - '98 STS
    Sure sounds like a plugged vent. Normally there is a vent tube attached to the filler pipe, but I don't see it in the diagram for your car.
    http://www.gmpartsgiant.com/Page_Pro...-008&SortKey=9
    There should be 3 lines from the tank. Supply, return and EVAP (which may serve as a vent, but I'm not positive).
    http://www.gmpartsgiant.com/Page_Pro...-016&SortKey=3
    EVAP system
    http://www.gmpartsgiant.com/Page_Pro...007&SortKey=52
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,606
    Doesn't the pre-2000 series have a tank vent solenoid at or near the charcoal canister ? Maybe that's used instead of a parallel fill pipe vent.
    Aug 2013
    59
    46
    that's what i am thinkin'... evap solenoid near the tank that runs to the charcoal canister. I had a Venture van fuel module I replaced for the GF's flower shop delivery van that had a decent sized hose attached by screw clamp to a nipple at top corner of tank. It was a real pain to get to, had to hold tank with floor jack half-way up then do the "feely thing" at arm's length with the air powered nut driver, as hose wasn't long enough to do while tank was on ground.
    Aug 2013
    59
    46
    Evap solenoid was the culprit!!! not a bad job, got a salvage yard special for $5.00!
  8. Remove Advertisements
