Results 1 to 3 of 3
Thread: Rear Brakes wear but fronts do not 98 Eldorado
    Hockey 52 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    4
    98 Eldorado rear brakes shot making noise fronts like new. Replacing rear pads wondering if this is a bleeding issue?
    69
    82,262
    Re: Rear Brakes wear but fronts do not 98 Eldorado
    If your brakes need to be bled the pedal will be spongy.
    The rears should last twice as long as the fronts.
    BlueAngel#07's Avatar
    BlueAngel#07 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,110
    You might have some fluid contaminants if it hasn't been changed in 2-3 years, or depending on how long you've had the car, might be the victim of two or three front rotor changes and the rear was ok at the time of the front change, and there just now catching up.
  • You may not post replies
