Results 1 to 7 of 7
Thread: Weird Loss of Power on Hill
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,232
    I was pulling out of a very steep driveway today; maybe 60 degree incline. I'm leaving the restaurant, start the car and go. I went to step on the gas and the tachometer didn't move at all. I started to think the car would soon stall.
    I know what everyone will say at first, but I've replaced my CKP sensors and IAC. It wasn't that feeling that the car stutters when idle. It was if the car was drive-by-wire and just not noticing the pedal was pushed in. It didn't feel like a misfire or stumble at all. The tachometer just didn't move. Then I let up and pushed the pedal again and it was suddenly normal again. No codes, I drove back hills the entire 10 miles home. No problems.
    Any thoughts? I did wash my engine yesterday. But any time I do that, I wrap all the electrical connectors in plastic and electrical tape then use the leaf blower to dry. I drove the car after washing it, no problems.
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    Re: Weird Loss of Power on Hill
    where you turning when this happened
    69
    82,262
    Got codes?
  5. #4
    ronluh is offline Cadillac Owners Member
    Automobile(s): Black on Black 2001 esc
    Nov 2011
    SanDiego
    30
    72
    Way to many connection's to cover up......did you check transmission fluid level??????
  6. #5
    Sep 2003
    NY
    1,232
    No codes, going straight, didn't check transmission fluid. I definitely covered every connection. I even took off the beauty cover, covered and taped the MDM connections and then put the cover back on.
    And why is there a question about turning? I think I may have a problem with my steering rack, but I wouldn't think that it could be related.
  7. #6
    69
    82,262
    Since it happened right after an engine wash I would almost bet it is a one time hiccup related to the wash. I'd ignore it unless it happens again.
  8. #7
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Transmission has nothing to do with it, if it was transmission the RPM would gone to the sky and the car would not moved.
    I would say TPS.
  • You may not post replies
