Shock and strut install
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Shock and strut install in Past Cadillac Vehicle Discussion; Im finally going to have time to get all this stuff installed on my Eldo this weekend . I was ...
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    450
    Im finally going to have time to get all this stuff installed on my Eldo this weekend . I was wondering of I should Spray some silicon on the rubber components , so they dont start squeaking after installation or is this an NO-NO ! Tx.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,875
    Re: Shock and strut install
    Nothing wrong with using spray silicone on rubber/poly bushings and spring/shock boots.
    Some of the sprays stay "greasy" and that only attracts dirt and grit. Use the type that says it "dries rapidly" - it's very runny, penetrates the assembly and dries to a slippery film - but it is not forever. Once a year ...................
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    I had to replace the lower rubber cushion under one of the front strut springs. It was worn clean through. Took care of the sqeak.
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,232
    Word to the wise, if you are doing them you should spring for new mounts and bearings up front. On a 2000, the rubber in the strut mounts has to be much softer than it was when new. If it hasn't already, it is a matter of time before its starts to develop small cracks. When the mount goes it is sometimes hard to see (after all, its the rubber that goes bad). The car will get sloppy and sometimes develop some front end noises that are difficult to diagnose.
    I would also consider replacing the rubber seats like EcSTatic said. They are about $10 each and may as well just do it while the struts are off. No matter what, don't say "the mount is fine". Replace that thing.
    Chuckj19's Avatar
    Chuckj19 is offline Cadillac Owners Member
    Automobile(s): 1999 STS-195,xxx (Daily Driver); 94 SLS-154,xxx RIP 2010
    Mar 2013
    Martinsburg, WV
    25
    27
    Quote Originally Posted by Yaemish View Post
    Those rubber seats are dealer only parts? I think its so stupid as you buy the strut mount kit but it does not include none of the rubber except the upper rubber..
  8. Remove Advertisements
