Transaxle Question?
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Transaxle Question? in Past Cadillac Vehicle Discussion; I have a 1995 SLS, while removing the radiator,I removed the lower transaxle cooler hose. and ran across alot of ...
    naccaratoj is offline Cadillac Owners Member
    Automobile(s): 1995 sls
    Aug 2013
    59
    5
    Transaxle Question?
    I have a 1995 SLS, while removing the radiator,I removed the lower transaxle cooler hose. and ran across alot of pressure when i cracked it loose, alot! Is that normal?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    No trans issues? Than I would say that is normal. My trans died and I had no pressure. Consider yourself fortunate.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    Re: Transaxle Question?
    With the engine off there should be no pressure anywhere in the cooler fluid circuit.............. the top cooler line (return) fitting is the one you pull and tap into to use a hose and bucket to pump all the fluid out of the transmission while doing a complete exchange. There has been no pressure in the cooler in the cars I have done.
    Somewhere in these forums, someone posted a circuit diagram of transmission fluid flow - to/from all 3 supply/scavenge pumps and torque converter.
    Aug 2013
    59
    5
    Thanks for the input, I guess nest i'll look for a pressure relief valve clog.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    There should be oil coming out of the lower line when you crack it.
    What do you consider pressure? Is if spraying out like a garden hose or just running out?
  8. Remove Advertisements
