04 SLS suspension problem - strut/shock substitutes
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 04 SLS suspension problem - strut/shock substitutes in Past Cadillac Vehicle Discussion; Looking for a cheap alternative to replacing the air shocks on the rear.....
    MrCadena is offline Cadillac Owners Member
    Jul 2013
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,547
    Re: 04 sls suspension problem
    Your post has nothing to do with warranty service or dealership interaction.
    Moved from Customer Care to the proper Seville forum.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    Re: 04 SLS suspension problem - strut/shock substitutes
    Quote Originally Posted by MrCadena View Post
    the "cheapest" thing to do IS to replace the rear air shocks -
    the Monroe MA822 is a direct-fir replacement -
    $62.71 for BOTH - with free shipping -
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    and if the air compressor or ride height switch are messed up -
    and you don't want to fix them right away -
    get the Monroe AK29 Manual Fill Kit - $12.56 - also from Amazon -
    the only other "solution" - and I use that term VERY LOOSELY -
    is to use the "coil-over" rear shocks -
    compared to the correct air shocks -
    they ride like crap - harsh - like a 1-ton truck -
    they ride high when the car is empty -
    and ride low with a load in the trunk and/or back seat -
    in other words - THEY SUCK -
    and regular shocks won't work either -
    the coil springs are soft - to give that Cadillac ride -
    and they need the extra support of the air shocks -
