1992 Eldorado suspension questions
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1992 Eldorado suspension questions in Past Cadillac Vehicle Discussion; I also have a 92 Eldorado touring coupe and the service suspension system message is present. The car has 55K ...
    aftonjay33 is offline Cadillac Owners Member
    Automobile(s): 1992 Eldorado
    Aug 2013
    30
    I also have a 92 Eldorado touring coupe and the service suspension system message is present. The car has 55K miles and the suspension is all stock is there something i should check? Is this a common issue with these? Tried to search forum but seemed like everything was about replacing the air system with a standard or modified suspensions. Thanks.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,569
    Re: resistor shocks for 92 eldorado
    Quote Originally Posted by aftonjay33 View Post
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Aug 2013
    30
    Thanks basscatt i didnt realize the suspension would be part of the computerized codes. I will check that out.
    Aug 2013
    30
    So I tried to pull the codes and I got code I039 Loss of Road Sensing Suspension data and it will not bring up RSS as one of the systems to check I am guessing because of the loss of the data in the ECM. Any ideas on how to get the RSS to talk to the system or what i might look for?
    Aug 2013
    30
    Re: 1992 Eldorado suspension questions
    Sorry to bumb this thread back to the top. Does anyone have any ideas on why the RSS is not supplying the data to the computer? The suspension appears to be functioning, i hear the compressor kick on ocasionally and it is sitting where I would think it is supposed to.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,569
    the RSS has electronics in each of the struts/shocks that vary the ride from soft to firm -
    I suspect this part of the struts/shocks are no longer functioning -
    yes - the physical dampening can still function -
    it simply remains at "medium" setting -
    rather than varying from soft to firm -
    and yes - the rear level control can also function correctly -
    in that it will properly maintain correct ride height -
    regardless of the weight in the back seat or trunk -
    NO - you can not replace the electronics within the struts/shocks -
    to eliminate the message on the display -
    there is a method of adding a relay to satisfy - and fool the system -
    it doesn't "fix" anything - it only keeps the warning message from displaying -
    you should be able to find information on that in the suspension forum -
    http://www.cadillacforums.com/forums...-brakes-tires/
    Aug 2013
    30
    Thanks basscatt, i appreciate the info. I am no expert but if it was just the actual struts/shocks electronics not furnctioning wouldnt 1.) be unlikely that all of them would be affected to the point that it is not sending any info to the computer. and/or 2.) shouldnt there still be codes being sent to the computer with codes for left/front damper, right rear damper etc.? Looking at the RSS codes in the one link in the "how to pull codes" sticky it seems like the RSS codes are mostly broken down by each corner. But the only code i get is the I039 loss of RSS data, and there is not even a selection for RSS when pulling the codes.
  10. Remove Advertisements
