2000 ETC - Theft System warnings
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 ETC - Theft System warnings in Past Cadillac Vehicle Discussion; Receiving current message: THEFT SYSTEM PROBLEM CAR MAY NOT START I have had the 2000 ETC since it was 2 ...
    eldo1977's Avatar
    eldo1977 is offline Cadillac Owners Member
    Automobile(s): 2000 ETC
    Dec 2005
    Michigan
    14
    Receiving current message: THEFT SYSTEM PROBLEM CAR MAY NOT START I have had the 2000 ETC since it was 2 yrs old and never heard of this message or what my (cheap) options maybe. Any thoughts? Thanks!
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Look at the pellet on your key, its worn down the ignition cylinder might need replacing
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: 2000 ETC - Theft System warnings
    Cheap solution >>>HERE<<<
    Is to be considered temporary solution until the defective parts are replaced/fixed.
    As Vincentm notetd above we are talking either of:
    1. Ignition key resistor contacts worn or very dirty - new ignition key with matching VAT
    2. Ignition cylinder contacts (worn, or broken wires) - new ignition cylinder + new matching key with matching existing VAT
    3. Harness issues between ignition cylinder and IPC (main culprit would be the big connector underneath the steering column).
    Most likely problem is no 2.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    I have the same issue right now, i have a new AC Delco ignition cylinder sitting in a box, for weeks now , just no info on how to replace it, in Alldata, ive asked here before but no response, i figure i can replace my turn signal switch new wiper pump wont work) as well when doing the Ignition Cylinder.
  7. Remove Advertisements
