No heat or ac
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, No heat or ac in Past Cadillac Vehicle Discussion; Removed passenger door due to accident. To make it easier or so I thought i cut wires to door. Now ...
    Medic9263 is offline Cadillac Owners Member
    Automobile(s): seville
    Aug 2013
    57
    5
    No heat or ac
    Removed passenger door due to accident. To make it easier or so I thought i cut wires to door. Now i am in defrost mode, no outside temp display or inside temp display, just dotted lines. Could there be connection between door wires and climate control probs. It worked fine before cutting wires.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Hook the wires back up and see what happens. U cut wires from old door. New door has same wires?
    Aug 2013
    57
    5
    Re: No heat or ac
    Gonna try that next.
    Aug 2007
    mpls mn
    2,528
    I figured you replaced door
    Aug 2013
    57
    5
    Re: No heat or ac
    After rewiring the door everything works again. Dont make sense.
  8. Remove Advertisements
