Results 1 to 7 of 7
Thread: Problem with shift lever '01 SLS
    surrfman is offline Cadillac Owners Member
    Automobile(s): 2007 DTS Performance Edition
    Aug 2013
    59
    46
    having issue with shift lever. When attempting to shift from Park, moving the lever first towards passenger, takes considerable force. Once moving down the selection range, moves as it should. Any input on what may be happening, what to look for, or just some plain 'ol lubrication is needed?
    Thanks guys,
    Timmy C
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Yeah, lubrication issue, or faulty shifter assembly.
    Aug 2013
    59
    46
    Re: Problem with shift lever '01 SLS
    That word "Faulty" sounds expensive!
    Any ideas on how to disassemble the console to allow examining the shift assembly?
    Thanks,
    Timmy C
  5. #4
    69
    82,263
    Put the shifter in drive or 3rd for better access and pull up on the shift knob. Once it is off, pry up on the wood panel. You'll have to unplug an electrical connector or two. Once that is off you should have access to the lube points or any other parts that need to be removed.
  6. #5
    Aug 2013
    59
    46
    Gonna try it right now...
    Thanks a bunch Ranger!!!
    Timmy C
  7. #6
    Sep 2010
    East Boston MA.
    29
    26,323
    You can't get to much with the shifter still in the console. You'll have to remove it. 4 bolts, and 2 cables. It's kind of self explaining pry once you see it. I can go into detail if needed.
  8. #7
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The side to side movement in the '98-'03 Seville is equivalent with the button press in the previous generation (or most of the cars).
    In order to move right, the brake must be applied, this will unlock the mechanism so you can shift out of park. Look into the interlock mechanism, looks like you have an issue with it.
    If you have even the slightest mechanical inclination, once you remove the wood trim on the central console your problem will become obvious, you can see all the movements.
  • You may not post replies
