95 eldorado wont start. Turn key and nothing happens. Please help!!!
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree4Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 eldorado wont start. Turn key and nothing happens. Please help!!! in Past Cadillac Vehicle Discussion; Turn key and nothing happens. All lights and radio work. After trying and trying to start it eventually starts. Had ...
    DeraldN is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado
    Aug 2013
    6
    Turn key and nothing happens. All lights and radio work. After trying and trying to start it eventually starts. Had new ignition cylinder replaced, bypassed vat key. Any ideas?????
    No security lights or disable lights flash
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,477
    Re: 95 eldorado wont start. Turn key and nothing happens. Please help!!!
    Quote Originally Posted by DeraldN View Post
    just off the top of my head -
    loose wire at the starter -
    starter solenoid -
    starter -
    ignition switch -
    starter relay -
    DeraldN likes this.
    68
    82,063
    Have you swapped out the battery with a known good one or had it load tested?
    DeraldN likes this.
    Feb 2003
    california
    69
    6,663
    Dirty and or loose battery cables at the battery. Remove them, clean them, reinstall them and report back.
    DeraldN likes this.
    Aug 2013
    6
    Battery is good, cables are clean. Once I get it started in the morning it starts fine the rest of the day. Was told it could be the passlock sensor?
    I will check the wires to the starter but I don't think that is bad. How do you check to see if the ignition switch is good? Thanks everyone for the replies. I love this site already :-)
    Feb 2003
    california
    69
    6,663
    So you did remove and clean them at the battery?
    Aug 2013
    6
    yes all clean
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    U did replace lock cylinder. Ur asking about replacing ign switch? I think they are both the same thing. Why did u change lock cylinder?
    Feb 2003
    california
    69
    6,663
    No they are not! Lock cylinder unlocks the steering wheel, completes the Pass Key code verification and moves the rod in the ignition switch down on the steering column. I presume the cylinder was replaced to possibly fix a PassKey mis communication.
    DeraldN likes this.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Quote Originally Posted by basscatt View Post
    ^This^ 9 out of 10 that I've seen.
    Don't over tighten.
    Why would you say that?
    Aug 2013
    6
    Because once i finally get it started in the morning it usually starts the rest of the day the first time i try.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Starter relay as it was stated above.
    There is no such thing as PassLock sensor.
    If you have issues with the Theftlock is pretty obvious there is a message on the dashboard telling "Starting disabled"
    Feb 2012
    NYC
    49
    1,948
    That is a symptom of a loose nut.
  16. #14
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Quote Originally Posted by Aztec ETC ECS View Post
    Or a corroded (or burnt contacts) relay...either of the 2 are highly plausible.
  17. #15
    Feb 2012
    NYC
    49
    1,948
    The reason it starts after it's driven is heat expansion. A few degrees will expand the cable eyelet enough to work for the day. After overnight cooling........
  18. Remove Advertisements
