90 Eldo Cooling fan Not always working.
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 90 Eldo Cooling fan Not always working. in Past Cadillac Vehicle Discussion; In AZ, temp outside was about 102. Have a 1990 Eldorado 38,900 miles, and the cooling fan has started to ...
    90SoCalEldo is offline Cadillac Owners Member
    Automobile(s): 1990 Eldorado,1991 Mazda Miata.
    Jul 2010
    San Tan Valley, AZ
    60
    22
    Have a 1990 Eldorado 38,900 miles, and the cooling fan has started to not go on when the temp goes up. Yesterday was out and the A/C shut off engine over heating, temp went to 250, have seen it go as high as 230.
    So came home, shut her down for a while to cool off, started her up let idle, A/C off, temp went to 230 and fan did not come on till I turned the A/C on.
    Temperamental temp sensor ?
    Have to have the compressor replaced anyway, leaking freon and oil.
    TIA
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: 90 Eldo Cooling fan Not always working.
    One fan or both fans are working? There is one on each side of the radiator.
    Jul 2010
    San Tan Valley, AZ
    60
    22
    Quote Originally Posted by drewsdeville View Post
    I got ripped off. Only have one. Does not seem to be enough room for 2.
    Oct 2004
    Oak Creek, WI
    5,607
    check the front side of the rad/condenser.
    Jul 2010
    San Tan Valley, AZ
    60
    22
    You are so smart Will check to see if they BOTH work.
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    So fans only work while A/C is running?
    Jul 2010
    San Tan Valley, AZ
    60
    22
    Ok, started her about 30 min ago, let her idle up to 225*, no fan's, turned the A/C on and only one fan came on, passenger side in front of rad. Is the driver side one suppose to stay on even when the car is shut off, when it is hot, like I hear others cars do? Temp did go up to 228*. then shut her down.
  10. Remove Advertisements
