Results 1 to 10 of 10
Thread: 2k eldo window motor replacement
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    450
    I need to replace the drivers side window motor in my2k eldo. I was looking at the fsm and it talks about removing spring tension before removing the motor. How do you do this. And how do you wind it up again. The fsm says nothing about this. On my 85 eldo I ran a bolt through part of window lift mechanism to secure the spring tx for the help!
    jammgm's Avatar
    jammgm is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS Luxury, 1998 Eldorado ETC Crimson Pearl
    Mar 2011
    West Haven, CT
    55
    368
    Re: 2k eldo window motor replacement
    I replaced the motors in my 98 Eldo which was simple. I put the window down first. The motor slides off three studs after removing the three nuts and unplugging the connector.
    If there's tension on the motor's gear, you'll find it difficult to remove the motor. To remove the tension , you have to pulse to window switch a little upward until the motor becomes loose. You may have to do the same when putting on the replacement depending on the gear position.
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    450
    Can the motor be accessed with the window down
  5. #4
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    No, you have to take the door panel off then follow jammgm's advise and poke around a bit with the wiring in the dor to make sure it didnt short out
  6. #5
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by ELDO GUY
    I refuse to believe you were asking if the motor could be accessed through a >1/2" wide slit.
    We're you asking if the lowered window would block access to the motor once the door panel is removed? If so, then yes, it would.
  7. #6
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    368
    Once you remove the door panel, (two screws then lift off the door.. do not pull outward or you'll break the clips), the motor is directly beneath the metal bracket where one of the screws was removed. In my 98, the motor is accessible regardless if the window is up or down and assume it's the same for your 2k Eldo. If you want to email me a private message, I can send you a picture showing it's location.
  8. #7
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    450
    Yes that would be good ive never had the door pannels off on this car so im not familiar with what it looks like in there l just dont want turn a simple job into a nightmare. Tx
  9. #8
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Lift door panel, do not pull out. On Seville, u can pop off speaker grille and see plastic panel clips on door panel bottom. I assume eldo panel is same design as Seville? There is 1 screw in corner behind hidden flap. Those GM interior designers are sneaky
  10. #9
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    368
    Eldo guy, send me your email via private message and I'll send some pics / details.
    Stoveguyy is correct. One screw is located directly under the control panel of the power windows and the other is behind the pouch at the outer end of the door on the bottom. You put your fingers behind the pouch and gently pull it out. If you never had the panels off, carefully lift them off since it's a common problem for the clips to break on these panels and could already be broken. There are some postings about how to repair them with metal clips. I did mine and posted some pics / details. Once the panel is off, the motor is right there.
  11. #10
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    450
    Tx for your replys . I will pm my email adress
  • You may not post replies
