Ac compressor not engsging sometimes
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, Ac compressor not engsging sometimes in Past Cadillac Vehicle Discussion; [QUOTE="CadillacEtc"]I have a 2000 Seville sts. Ac has been evacuated and recharged. Strange thing is it works perfect and cycles ...
    CadillacEtc's Avatar
    CadillacEtc is offline Cadillac Owners Fanatic
    Automobile(s): 2016 SRX Performance, 2006 STS 4,
    Boston, MA
    232
    [QUOTE="CadillacEtc"]I have a 2000 Seville sts. Ac has been evacuated and recharged. Strange thing is it works perfect and cycles normal. Somedays lately I put on the ac and the compressor won't engage at all and the only way to get it to turn on is to the race the motor to 3000 rpms twice then it works fine. Had the freon on the scale it at the proper level. Doesn't do it all the time but is happening more frequent now. I understand the compressor is suppose to cycle but that's njot the case
    Any ideas ?
    68
    81,748
    Re: Ac compressor not engsging sometimes
    The clutch is electromagnetic and there should be about a .025 gap when disengaged. I think the actual specs are .020 - .030. You could try to blow out the gap with compressed air. You'd be surprised at the dust that will come out. If that doesn't help, I'd measure the gap. It's possible it could need an adjustment. All this is assuming of coarser that it is getting current when it's supposed to.
    Boston, MA
    232
    I will check that tomorrow, how is racing the engine getting it to engage but when the car is shut off and started again it won't work until I race the rpms again ,
  5. #4
    68
    81,748
    Revving the engine is simply coincidental. I'd bet you could also get it to engage if you pushed on the clutch face with a long wooden handle.
    There is also the possibility that the clutch itself is failing.
  6. #5
    Boston, MA
    232
    I would like to think that but I could drive it an hour straight and it won't work till i stop race it quick to 3k once then once more and wallah it works and kicks on
  7. #6
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    actually - the compressor is NOT supposed to cycle -
    our cars use a "variable displacement compressor" -
    rather than constantly cycling to maintain correct pressures and AC demands -
    the actual movement of the pistons is adjusted -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    this is meaningless when it comes to diagnosing AC problems -
    SOMETHING is causing the compressor to cycle -
    when it shouldn't -
    to diagnose AC problems -
    you need to connect a quality set of guages -
    then post BOTH the HIGH pressure readings -
    and the LOW pressure readings -
    along with the ambient - outside - air temp -
    and the air discharge temp at the center AC vent -
    with the temp set at 60* and a medium speed fan -
    with the engine at a high idle - 1500 rpm -
  8. Remove Advertisements
