| Re: Burning carbon deposits... Not being critical here, but... using a spray bottle, and running the engine at the required RPM of at least 2000, there is ZERO chance of causing any sort of hydrolock condition first , due to the fact that the droplets are way too small, and second, if a droplet DOES hit the intake and become non airborne, 2 things will cause this droplet to disappear.. the amount of air moving thrut he intake will evaporate it along with the heat output from the engine.. the droplet would not last but a second inside the intake by itself.. if you happen to DUMP a bottle of water into the engine, then you would definitly run the risk of hydrolocking.. even if you put the spray bottle on "Stream", you would not hydrolock the engine.. the heat of combustion would evaporate too much of the water to cause hydrolocking.. I've only seen hydrolock occur in 2 occasions.. both of which were blown head gaskets into the cooling passage and having a cyllinder fill up with coolant overnight after cooldown and having that cylinder on the compression stroke. If the motor was very hot, any coiolant leaking in after shutdown would evaporate after hitting the inside of the hot combustion chamber. until the chamber is sufficiently cooled down and if there is enough coolant still able to pass thru AND the gap between the head, head gasket and block is not closed up doe to shrinking metal on cool down, you could then risk hydrolock.. how would you ever KNOW your cylinder is full of fluid? You'll find out when you crank the engine..
If your heads are ever removed, MAKE SURE THEY ARE RETORQUED after a couple of good driving sessions!!.. CHEAP insurance against needing new heads or chancing hydrolock. My first encounter with this was on a car we bought with a rebuilt chevy LT1 engine. The heads were never retorqued. after the first night of taking it out on a saturday night, we brought it home, parked it, and went to bed.. the car ran flawlessly all night.. next morning, treied to start, BANG BANG BANG BANG!!!!!..... opened hood, opened transmission cover, nothing.. did compression check.. one cylinder was a tiny bit lower than the rest.. kept playing with a few different things and checking.. nothing out of the ordinary.. yanked the motor.. found MOST of the head bolts could come out with slightly more than finger pressure... got the oil pan off and found the problem.. bent connecting rod.. caused piston skirt to hit the crankshaft counterweight.. why?? coolant leaked into the cylinder overnight.. the hi-torque mini starter just cranked right onto the connecting rod and forced it to bend.. also bent that part of the crank.. so.. make SURE your heads get retorqued.. |
