ckp sensor for STS2001
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, ckp sensor for STS2001 in Past Cadillac Vehicle Discussion; My STS2001 has 109K miles and stalled twice in the last 2 months at low speed. I am changing the ...
    john19999 is offline Cadillac Owners Fanatic
    Automobile(s): Seville STS 2001, Eldorado 1997
    Jun 2008
    Chicago, IL
    394
    My STS2001 has 109K miles and stalled twice in the last 2 months at low speed. I am changing the spark plugs and boots. There is npo code for ckp. I am not sure if I should change ckp sensore as well or see if car stals after changing the spark plugs or not. Also I see at rockauto that there are lower engine ckp and upper engine CKP. Do I need one each? CKP from standards is much cheaper than AC delco. Any idea about buying the cheaper one from Standards
    Thanks
    John
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: ckp sensor for STS2001
    Try cleaning the throttle body first.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    Your engine takes 2 CKP's - each different. Buy the AC Delco replacements (if necessary) and they'll fit and work correctly. I have no idea of which companies buy the DENSO (AC Delco) CKP's and re-brand them.
    More pictures in my albums and in RockAuto. Your best bet might be to talk to Chris in Parts at Rippy Cadillac tomorrow morning - over there >>>
    Zoom in on the picture - the part numbers are the second number from the bottom of each package.
    69
    82,381
    Being an '01 and randomly stalling with no DTC's points to CKP sensors. GM had a bad supplier from 2000-2003. Change them both. I did mine last summer and got them both on Amazon for $77 with free shipping.
    I think I may have the bad ones on my daughters '04 SLS. Hard to believe they have never been changed at 134K.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,847
    CKP - Crankshaft Position Sensors - are a known problem -
    and failing units won't always set codes -
    as Ranger put it -
    "it's not IF they will fail - but WHEN they will fail" -
    don't use anything but the genuine ACDelco parts -
    here are the best deals I found -
    ACDelco 213-1578 - $37.97 - with free shipping -
    from amazon.com -
    http://www.amazon.com/ACDelco-213-15.../dp/B000C9JORO
    and -
    ACDelco 213-1579 - $43.19 - with free shipping -
    also from amazon.com
    so $81.16 for both - with shipping -
    Jun 2008
    Chicago, IL
    394
    Thank you Basscatt. I will buy and instal these.
    Thanks
    John
  9. Remove Advertisements
