73 Eldorado Convertible window problems
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, 73 Eldorado Convertible window problems in Past Cadillac Vehicle Discussion; I have a 73 eldorado convertible I'm restoring, but none of the windows work. Whatcould be some of the possible ...
    jgosart is offline Cadillac Owners Member
    Automobile(s): 73 Eldorado Convertible
    Aug 2013
    28
    1
    I have a 73 eldorado convertible I'm restoring, but none of the windows work. Whatcould be some of the possible problems associated with the windows not working?
    -Bad Motors
    -Wiring Problems
    What other possible problems could it be?
    Feb 2003
    california
    69
    6,627
    Re: 73 Eldorado Convertible window problems
    The power to all the window motors goes to the driver door switch first, then branches out to the other three, so........... pull that switch and tell us if power gets to the switch. If it doesn't I would suspect a broken wire at the door hinge area where the wiring passes from the body to the drivers door. They are powered thru a circuit breaker, not a fuse. You might try replacing that circuit breaker first, but they usually don't fail.
