Speaker or Amp???
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Speaker or Amp??? in Past Cadillac Vehicle Discussion; Hi guys, My 2001 eldorado, Bose rear speakers have a buzz at low volume but seems ok at higher levels.. ...
    RazorBacker1's Avatar
    RazorBacker1 is offline Cadillac Owners Member
    Automobile(s): 2001 ElDorado ETC, 2005 STS V8
    Aug 2013
    North Little Rock, Arkansas
    37
    Speaker or Amp???
    Hi guys, My 2001 eldorado, Bose rear speakers have a buzz at low volume but seems ok at higher levels.. is it the speaker or the amp that will do this?? thanks for any help!
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Did the last run of eldo cars have Bose sub or not? Is that a deville thing?
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Eldos didnt come with a Bose sub
    Aug 2013
    37
    Re: Speaker or Amp???
    They have the amp attached to each speaker.. where the magnet is. I havent seen a Sub.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    On the older (late 80s 80s-early 90s) bose amps, the power supply caps would go bad, and when they started to go, the amps would buzz....maybe the newer amps do that too?
    Aug 2013
    37
    Thanks Kevin, now about the power supply caps.... how to locate or is it a complete replacement of amp's.... not sure how the speakers come out yet but laying in the trunk is a bitch. Thanks for the info.
    ZeroOctane's Avatar
    ZeroOctane is offline Cadillac Owners Fanatic
    Automobile(s): 1993 4.9L Seville - Navi w/ backup cam, 40 Series Exhaust
    Sep 2007
    New Hampshire
    448
    Quote Originally Posted by RazorBacker1 View Post
    I just replaced both the amps in the trunk. Once you find yourself crawling into the trunk of a nasty salvaged cadillac that's been sitting exposed to mother nature for years you'll be missing the cozy trunk of your car...trust me.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Yes BOSE equipped Eldorado has the mono amplifier for each speaker.
    Very easy to diagnose if is the speaker of the amplifier:
    Volume to minimum (mute), do you hear a buzz, then is the amplifier.
    Generally a bad speaker will only make distorting sounds at medium to high volume and mainly on the medium to low frequencies.
    A bad speaker will make a mechanical sound (something is touching something else) or it rattles, very different than the buzz of an amplifier.
    You can replace the amplifier alone (very difficult) from the trunk without removing the speaker (you will be laying on your back with the hands in all kinds of highly uncomfortable positions). Probably in the process you will pop the speaker out of its mounting tabs (minimum amount of vertical force will do so). You can't put it back unless you remove the rear seat (backrest and all) to be able to remove the rear deck cover to access the top of the speakers.
    Or you can just remove the speakers (like described above) and work on a bench in a comfortable position.
    Aug 2013
    37
    Thanks for the info guys!.. think I will be doing the speaker removal and then the amp replacement. Comfort is important. it keeps frustration down. I have been doing some repairs to my Eldo thanks to this forum and the great info you can get from the guys that know what they are talking about. Thanks again!
  12. Remove Advertisements
