76 Eldorado Cruise Control Issues
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, 76 Eldorado Cruise Control Issues in Past Cadillac Vehicle Discussion; I can use some help here. I noticed one of the rubber isolating bushings at the transducer was broken and ...
    bluefleetwood's Avatar
    bluefleetwood is offline Cadillac Owners Fanatic
    Automobile(s): 1964Fleetwood60Spcl,1976EldoradoConv,2009CTS4BlackCherryDI
    Jan 2010
    Long Island, NY
    327
    I noticed one of the rubber isolating bushings at the transducer was broken and Ive replaced it.
    Cruise was working fine up to point when it broke. Reinstalled and no luck getting cruise to operate.
    Both indicator lights illuminate. The on off switch as well as the green indicator after turn signal switch is depressed.
    Bought a rebuilt transducer and swapped it out with no success.
    Any ideas?
    Thanks.
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    42
    4,023
    Re: 76 Eldorado Cruise Control Issues
    1. is the chain attached between throttle and vacuum activator?
    2. Are all the vacuum connections attached to the transducer?
    3. Are all vacuum lines attached from/to carb/engine? No leaks/blocks?
    4. Are you sure the rebuilt is working?
