Well hello there jbrown93etc,
The 'clutch bearing' on my Henderson64 piled up. At first I thought it was the belt (that's a pretty easy fix right), nope wasn't it. Then I pulled out the stethascope to isolate the noise I was hearing. This in itself is impossible because everything is tied together with the serpintine belt and any sound simply transfers. Next step was trial by elimination, first the all the pulleys were checked (the AC pulley hadn't yet gotten bad enough to isolate as the culprit), then I just started removing and inspecting each pulley, starting with the easiest ones (idler, tensioner) first.
Unfortunately, I had to remove the compressor to test it, and in doing so, had to remove the alt/gntr in order to get at it.
You should know, there's barely enough room to get a beam of light in and around the compressor, let alone any tools (not to mention your hands), so if you're going to attempt this service task, be prepared for a challenge.
All in all though, it's totally worth it to do in your own garage if you have one.
The dealer/s priced the job at $2600 +/- a couple hundred.
The privates priced it at $1800 - $2200 +/- a couple hundred.
The cost of a replacement OEM compressor came in around $900.
A rebuilt came in around $600.
I could've gotten a rebuilt unit out of the US for around $360-$400 after costs.
I opted to search for a used unit out of the wreckers $257 delivered.
I reconditioned it myself (not a big job when everything is on the bench).
My cost to have a leakdown/pressure test and re-energize the system was $140.
My total out of pocket for the job turned out at $400CDN vs $1800-$2600 from a shop.
My savings on the job $1400-$2200 (if I average it, I saved $1800CDN).
This does not include replacement and reconditioning of the other parts (idler $22, tensioner $46 and serp-belt $56, roughly another $140). Nor does it include additional time given to reconditioning all the oil, comppressor and cooler hoses, or the o/filter mount reconditioning. Resecuring pan fastners around the trans/oil pans. Lubing all the joints and such.
In my opinion, if you're going to attempt a job like this, you mays well take care of whatever you can while you're in the are, because it's just a POS job and you don't want to go in there any more than once if you can avoid it.
Hope this answers your question.
Oh, one thing I should ad here, I drive other vehicles as well, so it wasn't an issue for me to tie the Caddy up for a couple weeks (evening work only), the wife didn't care for it so much, but WTH, she didn't repair it either.
So if you're looking at a fast repair because this is your principle transportation, your going to have it apart and back on the road in about 6-8Hrs.
Good luck...
