STS now in for...sigh...headgaskets...
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 56
Like Tree9Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, STS now in for...sigh...headgaskets... in Past Cadillac Vehicle Discussion; With all the work I had done to this car before, now the head gaskets go after another 18k miles....I ...
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    With all the work I had done to this car before, now the head gaskets go after another 18k miles....I guess 176,000 miles isn't sooo bad...just aggravating.
    Found a replacement engine for the car....only has 6,000 miles on it. Yeah, you read that right, 6,000 miles on it.
    A guy I know had bought it out of a wrecked 2000 DTS back in like 2001 or 2002.
    He sealed every conceivable opening and wrapped it in shrink wrap.
    This is what it looked like when it showed up, unwrapped of course...
    I feared the block seal may have dried out (a little seeping at the seam) and didn't want to take the chance that it would leak in the car, so I split it and am resealing the block.
    Check out these pics:
    Overall:
    Bearing journals:
    Cylinder bores:
    I'm loving this find....not bad for an engine that has been sitting for over a decade...
    Next comes the rather tedious task of taking the motor out of the top because I 1) don't have a lift and 2) don't want to redo the front end work...
    orconn's Avatar
    orconn is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac 95 STS, 02 SLS
    Oct 2007
    Midlothian, VA
    73
    13,792
    Re: STS now in for...sigh...headgaskets...
    I wish you well! Keep us posted.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    That engine looks really clean!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,253
    You have your hands full, Chris. Good luck !!!
    DTS to STS = some cooling system piping work.
    Feb 2009
    Jacksonville, FL
    1,023
    Jim, basically everything is coming off the STS and being bolted to this DTS block, the only cooling piping that I can see is maybe the water pump crossover, but that's being removed too...
    any other thoughts/surprises that I might be in for?
    Feb 2009
    Jacksonville, FL
    1,023
    found the plumbing snafu...the EGR system isn't plugged into the DTS exhaust manifolds...odd, buit no big deal, just swapping manifolds...
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,046
    Are you planning on studding the head on this one to save you another HG surprise??? I would highly recommend it since it's already out of the car...
    Feb 2009
    Jacksonville, FL
    1,023
    don't have the cash for that right now, but I'll have another Northstar as soon as it comes out...
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Back in the day, northstar headgaskets never failed at 1yr/10k miles? We would need a time machine to go back to 1999 and take a poll of how common it was for 1yr old cars to have warranty issues on heads?
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Quote Originally Posted by the recluse View Post
    Id really hate to see it leak or have a HG failure, id strongly recommend studding while it's out. If i could help you obtain a set of studs, i would.
    Aug 2007
    mpls mn
    2,528
    You have a very low miles motor which should be good but could be improved with studs
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by vincentm View Post
    The problem I have is with a new motor, I'm afraid the trans is on the chopping block next....I'm trying to save up to get that gone through, otherwise I fear I won't have to worry about the HG's...
    My last motor went 175K+ before it let go. Even if this one only gets me to 130K, that's still about 4 1/2 years out at the rate I drive and when I get my wife's car done, this car will sit it out and hardly get any miles on it....
    Now, for those who have pulled this motor out from the top, I bow to your abilities....I tried, but I failed and decided to pull the thing out the bottom...
    Feb 2009
    Jacksonville, FL
    1,023
    Here is the difference between the two manifolds. You'll notice the EGR "bib" sprouting out past the manifold flange...
  16. #14
    Feb 2009
    Jacksonville, FL
    1,023
    Now it's been awhile (don't ask why, it's depressing enough), but I finally got back to putting the Northstar back together...
    One thing I noticed, and was not particularly fond of, is the amount of restriction in these exhaust manifolds. They're welded together and where they started wraps around to the point where they ended and overlapped to this big blob of weld...
    Now they're hard to see through the carbon build up, but it's thick, tall, and bottle necks the flow, so I trimmed the weld a little with a dremel...
    I did them all. Don't know if it'll be of any real benefit, but...it's done anyway, lol
  17. #15
    Feb 2006
    56,253
    Did you Dremel the collector Y ?? The left bank(front) pipe is usually stuck into the larger right bank(rear) pipe and welded - leaving a lot of pipe protruding into the Y. Pictures in the Northstar files a year or so back.
  18. Remove Advertisements
