STS now in for...sigh...headgaskets... - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 56
Like Tree9Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, STS now in for...sigh...headgaskets... in Past Cadillac Vehicle Discussion; Yeah, I got that...the "key" is also on the squared connector...same spot, just squared... I thought it was odd, really......
  1. #31
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: STS now in for...sigh...headgaskets...
  2. #32
    Closet Boy's Avatar
    Closet Boy is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SLS
    Jun 2005
    University Heights, Ohio
    254
    Good stuff. Looking forward to your future posts. Keep up the good work.
  3. #33
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    So you surfaced after a ~7 year vacation ???? (Last post was 08/07 !)
  5. #34
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by Submariner409 View Post
    Duh, that's why they call him "closet boy"...
    So...wait...he came out of the closet on my thread...?
    At any rate, thank you...
    maeng9981 likes this.
  6. #35
    Feb 2009
    Jacksonville, FL
    1,023
    IT'S FINALLY IN THE HOLE!!!
    Will post more later, maybe when I get running...
  7. #36
    eldorado_sean's Avatar
    eldorado_sean is offline Cadillac Owners Enthusiast
    Automobile(s): 98' Eldorado ESC
    Sep 2012
    Burbank, California
    740
    Make sure you take some pictures and a video if possible! I've been following this thread since the beginning. Good job!
  8. #37
    Feb 2009
    Jacksonville, FL
    1,023
    I don't know, but I think I wasted my money on this headlight repair kit...
    Needed something to do while the weather is bad...
    They are both done now, but it is sleeting outside and I can't put them in...hell, I can't even work on the car...
  9. #38
    Feb 2009
    Jacksonville, FL
    1,023
    With all the crappy weather we've been having around here, it's hard to make solid progress on the car...so I have been doing things on it that I can do inside...like repainting the beauty cover...
    Some may remember the old paint scheme I had on the motor...
    To me, it lacked the definition that I wanted...so this time I painted the risers on it too...
    I like this a lot better...
    curtc, alexmst, sts 03 and 1 others like this.
  10. #39
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Damn That looks good. I want to do that to both mine since I got them, stock cover ugly.
    I'm going to try and find paint you used and any tips.
  11. #40
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by rodnok01 View Post
    It's Cummings Beige and satin black.
    I chose those colors because the car is bronze with a saddle interior and carriage top...that and the motor is partly black.
    I painted the beige first, then taped the basic outline with an edge lock tape...created a set of templates out of laminate for countertops to cut out the areas in black so all would be uniform.
    A few hours of layout and painting...
  12. #41
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    So just generic engine paint basically? didn't know it it needed to be plastic specific paint. Do you think a regular paint would hold up that I can match to the car? I paint a lot of under hood stuff, just usually basic colors and stick to metal parts.
    Thanks, want to do right the first time.
  13. #42
    Feb 2009
    Jacksonville, FL
    1,023
    I wet sanded the "NORTHSTAR 32V" off of the front of the cover to get it flat and smooth and had the casting bubbles come through the urethane...sucked...
    The first time I painted it with Krylon flat black for plastics which hid a lot of the bubbles (the paint stuck very well), this time I had to go back and block (wet sand) the crap out of the paint to get rid of them.
    I would just suggest that if you sand through all of it to the urethane (the original paint cuts quick with a 400 grit wet/dry), get a urethane etching primer (adhesion promoter) and dust it (no need for a heavy coat), then spray it with a sandable primer to fill in all the holes...with this as a base you can spray whatever you want on it.
    If you don't want to front for a good adhesion promoter (they can be expensive), get a flat plastics paint, coat it fairly heavy, and sand it down smooth (but not through the paint), and then get a grey sandable primer and start working your colors from there...
    The engine cover doesn't see any kind of really hot temps to be worried about the paint falling off...
    Lifer likes this.
  14. #43
    Feb 2009
    Jacksonville, FL
    1,023
    For the love of...
    Bought new radiator because old one was, well, old...the last thing I have to do to start filling and firing is connect the top trans cooling line to the radiator...
    whatever engineer thought it was a brilliant idea to have one aluminum fitting screw into another was an idiot...
    Stripped out both the connector AND the radiator...hoping a radiator shop can do something for me otherwise I just wasted $160....
  15. #44
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Not sure if this model is different, but usually those line connections are o-ringed. You only need to compress the o-ring to get a seal. Aluminum should have been adequate for this application. No need to he-man the connection...
  16. #45
    Feb 2009
    Jacksonville, FL
    1,023
    It wasn't the he-man thing, it's the angle of approach...hard to see if it's in square...especially at night...
    Radiator shop said they will fix for $45....sigh...better than another new unit...
  17. Remove Advertisements
