ALC Replacement
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, ALC Replacement in Past Cadillac Vehicle Discussion; I just replace my compressor because my car was jacked up due the exhaust valve failure . I tested my ...
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    450
    ALC Replacement
    I just replace my compressor because my car was jacked up due the exhaust valve failure . I tested my junk yard replacement and it was fine once installed it failed to inflate the shocks. I know I didnt have any leaks because my car was jacked up all the time. Any ideas on this one tx.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: ALC Replacement
    Quote Originally Posted by ELDO GUY View Post
    I assume you checked all the related fuses - and the compressor runs -
    that means either the compressor itself is worn out -
    and not supplying air pressure -
    or there is a leak either in the compressor - or the air lines -
    or the exhaust valve is stuck open -
    thus immediately venting any air the compressor is producing -
    if the original compressor worked - except for the failed exhaust solenoid -
    you could try swapping the junk yard exhaust to the original compressor -
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Hmmmmm?
    Don't mind me, jus wanna be able to find this thread latter
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    450
    Re: ALC Replacement
    Thanks for the Ideas . The compressor is powered. The old one works fine except for the exhaust solnoid . Is there any way to test and see if the compressor is weak . I can feel the air coming out of it when I power it up . I dont think I have any leaks because the car was always Jacked up. if it had leaks I assume it wouldnt stay jacked up .
  7. Remove Advertisements
