Another water crossover question (sort of)
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, Another water crossover question (sort of) in Past Cadillac Vehicle Discussion; Greets, In the process of removing the WC I've found two rubber(?) connector hoses running to what I think are ...
    DJSG3 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Deville DTS
    Dec 2005
    Joisey
    254
    Greets,
    In the process of removing the WC I've found two rubber(?) connector hoses running to what I think are the heater pipes. One of them connects to the WC right below the EGR valve. These hoses are green on the outside and red on the inside and only about 2inches long each. Anyone know what this type of hose is called & where I can get more of them?
    DJSG3
    69
    82,171
    Re: Another water crossover question (sort of)
    They are silicone and are used in that location because of the heat. I suspect most auto parts stores should carry it, but I've never had to buy one so I'm not 100% sure.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    After having difficulties on finding a place that sells silicone hoses, I just went with regular reinforced hoses. It works fine.
    Dec 2005
    Joisey
    254
    Thanx for the info. Reckon I'll see if I can find them 'cos their so pretty.
    DJSG3
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The dealer can get you the silicone hose if they don't stock it.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,588
    Talk to Chris in parts at Rippy Cadillac over there >>>>
    Platinum Vendor, way up there ^^^
    LloydCFerguson is offline Cadillac Owners Member
    Automobile(s): 1997 ETC, 2002 STS
    Mar 2012
    Glendale, CA
    44
    Quote Originally Posted by Submariner409
    You can (or at least used to be able to ) buy them from GM cut to length.
  10. Remove Advertisements
