1997 STS VATS problem
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1997 STS VATS problem in Past Cadillac Vehicle Discussion; i have a 1997 Seville STS an it shut down going down the road when i was passing someone an ...
    97pearlSTS23 is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac STS
    Jul 2013
    26
    5
    i have a 1997 Seville STS an it shut down going down the road when i was passing someone an i got the dreaded "theft system problem, Car may not restart" but when i checked my OBD the theft system didnt show up.. the fuel pump wouldnt come on but when i removed the pump an hooked it strait to a battery it came right on.. please help ive tried almost everything
    zek4964 is offline Cadillac Owners Fanatic
    Automobile(s): 08 cts 68k, 07 STS-V 15K, 97 Sts 160k
    Jun 2010
    Rochelle IL
    302
    Re: 1997 STS VATS problem
    Search Vats jumper, i think there is a way to get around it by installing a few resistors under the stearing collum. A lot of those problems come from your key cylender on the steering collum.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    When you insert the key in the ignition cylinder there are 2 contacts inside touching the little pallet at the base of the key blade. That pallet is a resistor and this resistor will have one of the 15 possible values:
    1) .402 KOhm (.386KOhm-.438KOhm)
    2) .523 KOhm (.502 KOhm -.564 KOhm)
    3) .681 KOhm (.650 KOhm -.728 KOhm)
    4) .887 KOhm (.850 KOhm -.942 KOhm)
    5) 1.130 KOhm (1.085 KOhm -1.195 KOhm)
    6) 1.470 KOhm (1.411 KOhm -1.549 KOhm)
    7) 1.870 KOhm (1.795 KOhm -1.965 KOhm)
    8) 2.370 KOhm (2.275 KOhm -2.485 KOhm)
    9) 3.010 KOhm (2.890 KOhm -3.150 KOhm)
    10) 3.740 Kohm (3.590 KOhm -3.910 KOhm)
    11) 4.750 KOhm (4.560 KOhm -4.960 KOhm)
    12) 6.040 KOhm (5.798 KOhm -6.302 KOhm)
    13) 7.500 KOhm (7.200 KOhm -7.820 KOhm)
    14) 9.530 KOhm (9.149 KOhm -9.931 KOhm)
    15) 11.800 KOhm (11.320 KOhm -12.290 KOhm)
    Basically the key will become part of an electrical circuit so the IPC can read the value of the resistor in the key and validate if is correct (will compare the value with the one stored in its memory as expected value). If is in the acceptable range will sent "start enable" the encrypted message.
    When the PCM receives the message will enable the started and fuel pump relay AND the injectors. Just by jumping the fuel pump relay will still not make the engine start as the injectors are disabled (off).
    This is the diagram of the circuit:
    If the started enable password is not received the PCM will not start the engine, also the IPC will display "Starting disabled remove key", then every minute will refresh the message with "WAIT 3 MINUTES", "WAIT 2 MINUTES", "WAIT 1 MINUTE", "START CAR". It will also post a theftlock code that will turn to history in the moment the correct VAT is read.
    You have an issue somewhere on circuit 173 or 174. Most common points of failure (bad contact) are the contacts inside the ignition lock cylinder, the key terminals (mat be dirty or worn out), the contacts inside the C202 connector (pin E12 or E13) or the very thin wires between ignition cylinder and the C202 connector (sometimes they break).
    You can temporarily bypass the system by installing an appropriate size resistor as shown here:
    To find out the correct resistor value measure the key resistor using an ohmmeter with the leads touching the contacts on the ket on each side of the key blade.
    With the bypass you can spend the time and find exactly where the issue is, wires, key or Ignition cylinder.
    More about this bypass find >>here<<
    Oh and one more thing, if you feel the need to cut any wire DON’T, you are doing it wrong.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    I've never seen a car shut down while running due to a VATS problem, just no start.
    Also seen a few cars start just fine with "theft system problem, Car may not restart" message. Go figure.
    Quote Originally Posted by N*Caddy View Post
    I don't know when this became a Federal offense. I've done at least 50 over the years by cutting & jumping the 2 white wires in the orange casing with the correct resistor. OCD thing?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    VATS didn't cause the engine to stall, you have more than one problem.
    68
    81,917
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    No, VAT will not cause the car to stall once started (is a safety issue), but will prevent it from starting.
    So unless you get the messages I mentioned ("THEFTLOCK ENABLED, REMOVE KEY", "WAIT...") is not a VAT issue.
    Now as for wire cutting, he may cut the wires then find out the issue was in the big connector underneath the steering column, now what...
    WHY cutting wires when you can unplug the connector (like I described) have your temporary fix done, nothing damaged in the process, then take the time to see exactly what went wrong.
    There is one thing I REALY HATE, the shops doing rust proofing (spray some oil in the doorsills). They drill holes in the doorsills right next to the existing factory holes. All you need is pry the plastic covers and there are 4-5 holes in there (1 inch away from the one they drill). This qualifies the same as cutting the wire 1 inch away from the connector when you can just unplug the connector. Plus I explained many times the bypass should be done at the IPC connector not somewhere half way on the wiring, what if the issue is upstream on the wire?
    Like I said you NEVER EVER need to cut a wire, there is always a connector on the circuit.
    Here is a very graphical example:
    Jul 2013
    26
    5
    well i appreciate the advice.. i still havent had any luck on my own.. some one suggested it could be a cam sensor keeping the fuel pump from kickin on. Any ideas on that?
    68
    81,917
    That doesn't sound logical. I do not believe there is any relationship between the two.
    Sep 2010
    East Boston MA.
    29
    26,325
    None at all.
    Jul 2013
    26
    5
    well i did some research an i guess i may have misunderstood... it seems the crankshaft position sensor is the one that can cause a stall out during heavy acceleration an keep the fuel pump from coming on as a safety measure but i cant find anywhere that it tripped the vats system.. in at a complete loss, ive never had a problem such as this
    Sep 2010
    East Boston MA.
    29
    26,325
    CKP sensors have nothing to do with the fuel pump, and usually cause stalling while slowing down/stopping.
    The only thing that will disable the pump is VATS.
    Stalling under hard acceleration, and an INOP pump? Are you sure the pump hasn't failed.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    CPK actually stall the engine under no load (idle) like when coasting down to a stop.
    You have a different issue.
  16. #14
    autoed is offline Cadillac Owners Member
    Automobile(s): 1998 deville
    Aug 2013
    3
    Really not positive but I believe VATS will not disable a vehicle that's running. I think I would test the fuel system for another problem,maybe a relay? I have had vehicles with VATS if they were running and they had a security issue they would stay running but would not restart. I think the security light was a result of the stall.
    N Caddy nice explanation of VATS and how to "test" with resistors
  17. #15
    Jul 2013
    26
    5
    ok i got the "theft system problem, Car may not restart" message to stop, i found a sensor unplugged an a ground wire jus dangling... but my fuel pump still isnt coming on... Any ideas?
  18. Remove Advertisements
