2000 SLS transmission shifting between 2-3 c
Results 1 to 10 of 10
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 SLS transmission shifting between 2-3 c in Past Cadillac Vehicle Discussion; Car shifts around 4000rpm then drops too under 1000 almost killing car please help will go 35mph max...
    dogottie is offline Cadillac Owners Member
    Automobile(s): 1999 sts
    Jun 2013
    31
    5
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: 2000 sls trans mission shifting between 2-3 c
    Does the car feel like it has significantly less power than normal?
    The more you get in the gas, the slower it goes and the later it shifts?
    Jun 2013
    31
    5
    Yes it does feel like that I hit gaz rpm goes down sun time my rpm won't go over 4k
  5. #4
    Feb 2012
    NYC
    49
    1,948
    Possible clogged cat. Often mistaken for trans problem.
  6. #5
    Jun 2013
    31
    5
    Hmmm I will check n too that my onscreen display flashes service transmission I just hoping I dnt need a new tranny lord Jesus
  7. #6
    Feb 2012
    NYC
    49
    1,948
    That's different. Check codes.
  8. #7
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,997
    If you have Service Transmission message, there's a code set. It's usually not good.
  9. #8
    Feb 2012
    NYC
    49
    1,948
    Now that I think about it, I've never seen a Service Trans message in one of these cars.
    Does it come on with a trans fault or when fluid life hits zero?
  10. #9
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,997
    It happens when some of the trans codes are set, for example, P1811 - Maximum adapt and long shift.
  11. #10
    Feb 2012
    NYC
    49
    1,948
    Re: 2000 SLS transmission shifting between 2-3 c
    I've seen & done trans work on many of these cars and have never seen that message.
  12. Remove Advertisements
