Filler neck Replacement
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Filler neck Replacement in Past Cadillac Vehicle Discussion; I need to replace my filler neck on my 2000 STS. The replacement that dorman sells is $47 but has ...
    stsjohn1 is offline Cadillac Owners Member
    Automobile(s): 2000 STS
    Oct 2011
    36
    I need to replace my filler neck on my 2000 STS. The replacement that dorman sells is $47 but has the two lines coming off it. The one I have is a single tube down to the rubber hose.
    If someone has info. if the two line (vented) is easy to install? an option or not. The other option is $400.00.
    Thanks.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: Filler neck Replacement
    The Dorman filler neck is not designed for your car if it has 2 lines.
    Also I am not sure if $400 is the worst part. You may find out that having the $400 you can't get the OEM part either (may be discontinued by now).
    Oct 2011
    36
    Thanks for your input.
    Rock auto has the Dorman part listed with the more expensive one as viable. Sorry the other part is $464.00 not $400.00.
    The fuel neck was wore part way through by the tire after the leveling system failed. I would suggest a Design issue.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    And the short hose connecting the filler neck with the fuel tank is $98 (at least for my year), been there done that.
    I can’t imagine how the filer neck be damaged due to leveling system failure, even with the ELC out the spring should maintain the normal ride height (assuming no load is added to the rear). Also for gen IV Seville the filler neck is way away from the tire even if it bottoms out, not sure gen V (I would assume similar).
    rodnok01's Avatar
    Feb 2012
    NC
    6,624
    If the steel portion has a hole wore in it get it patched, can't for the life of me see how it could have but hey what do i know.
    Oct 2011
    36
    The plastic casing was wore away. I can see the metal tube and it seems OK (no spillage of fuel).
    I believe the space between the inside of the plastic casing and the metal fuel tube is the pressure relief?
    flatback's Avatar
    flatback is offline Cadillac Owners Member
    Automobile(s): 98 Eldo ETC & 2003 Seville SLS
    Mar 2009
    Philly burbs
    62
    I just bought one for my 98 Eldorado at www.fillernecksupply.com $100 and change. Worked fine and they seemed like good people. Do not mess with it, a pinhole will eventually be a big hole and when you go to fill it with gas you'll have a flood, happened to me
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    The Internet is great. Its easy to find MYITEMFORSALE.com, who says you can't make a buck these days?
  11. Remove Advertisements
