96 ETC code P 0139
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 96 ETC code P 0139 in Past Cadillac Vehicle Discussion; code p0139 others causes besides o2 sensor? can maf sensor be dirty?...
    opticallab Guest
    Unhappy96 ETC code P 0139
    68
    81,887
    Re: 96 eldorado touring code p0139
    What's P0139 mean?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: 96 ETC code P 0139
    Yep ^^^
    We don't have the several thousand codes memorized yet ............. Do some homework.
    http://www.obd-codes.com/trouble_codes/gm/obd_codes.htm
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    DTC P0139 HO2S Slow Response Bank 1 Sensor 2
    But his is a 96, wouldn't this be an OBDI vehicle? Or a bit of both OBD I & II? Or is that 95's?
    I need a beer
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    96 should be OBD II
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    '96 cars are mostly OBDII (enough so they comply with the Federal law). We can call '96 a transition year (sometimes when dealing with '96 vehicles you may need to go and check OBDI codes).
    This code is OBDII and I found it for the OP:
    Basically replace that O2 sensor.
    68
    81,887
    The '96 PCM codes are OBDII. I think most of the others where still OBDI until '97.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    how long does code take to return after you clear it? i am getting 0140 which is no activity. i did change sensor 18 months ago. code went away but recently came back.
  11. Remove Advertisements
