Front strut sensor bypass. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Cadillac Seville / Cadillac Eldorado Forum Discussion, Front strut sensor bypass. in Past Cadillac Vehicle Discussion; I installed the resistor on the harness side where it plugs into the strut. Both front struts have a wire ...
  1. #16
    Pete315 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Feb 2009
    305
    Re: Front strut sensor bypass.
    I installed the resistor on the harness side where it plugs into the strut. Both front struts have a wire connection ( 2 wire plug). Yes, I have height sensors in the front and back. I don't have F45.
  2. #17
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Then you DO HAVE F45, wires to the struts, 4 height sensors, RSS module = F45.
    But because is a '95 the controls are different (almost sure). Most likely the resistor will not work (at least not with that value).
    Again do not cut wires, is all I am saying.
  3. Remove Advertisements
