Time-Sert or Helicoil, which would be the better fix for a belt tensioner bolt hole.?
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By vincentm
Cadillac Seville / Cadillac Eldorado Forum Discussion, Time-Sert or Helicoil, which would be the better fix for a belt tensioner bolt hole.? in Past Cadillac Vehicle Discussion; to repair the threaded hole for the belt tensioner bolt? this bolt has the following specs: Dia: M10mm Pitch: 1.5mm ...
    firstimecaddi is offline Awaiting Email Confirmation
    Automobile(s): 94 Seville; 95 FWB
    Apr 2006
    Out of my mind
    653
    Dia: M10mm
    Pitch: 1.5mm
    Length: 57.5 mm
    Drive: 13mm
    Torque: 50 Nm or 37 lb/ft
    Thanks
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: Time-Sert or Helicoil, which would be the better fix?
    Never, ever ever ever ever use helicoil. I wouldn't even recommend Timeserts, only Normserts or studs
    http://huhnsolutions.com/
    C
    arrollcustomcadillac.com
    Northstarperformance.com
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    Quote Originally Posted by firstimecaddi View Post
    Dia: M10mm
    Pitch: 1.5mm
    Length: 57.5 mm
    Drive: 13mm
    Thanks
    to repair the threaded hole for the belt tensioner bolt -
    a helicoil - with some thread-locker should be fine -
    Quote Originally Posted by vincentm View Post
    C
    he is only trying to fix the threaded hole for the belt tensioner bolt -
    GEEZ - you can't "stud" EVERYTHING on a Northstar motor -
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Quote Originally Posted by basscatt View Post
    My bad the name helicoil creates a kneejerk reaction lol
    basscatt likes this.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    He probably read the thread title a d assumed the OP was talking about HGs.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Yup lol
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    I assume so -
    but since he has been having such a wonderful - productive day -
    I thought he needed a little JAZZ -
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    I assume so -
    Yea, shock absorbers and oncall for the hospital. I ciuld sure use a beer right now. But i gotta be on standby till monday morning
    DJSG3 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Deville DTS
    Dec 2005
    Joisey
    252
    Measure the depth of the bolt hole and then put the bolt in the tensioner and measure the threaded length that sticks out of the back of the tensioner. If the hole is deeper you might want to try getting a longer bolt, thats what worked for me.
    DJSG3
    Apr 2006
    Out of my mind
    653
    @DJSG3....is helicoils overkill?
    if doing helicoil insert, is there anything in particular that I should look out for or avoid altogether?
    Apr 2006
    Out of my mind
    653
    Re: Time-Sert or Helicoil, which would be the better fix for a belt tensioner bolt ho
    OK some more info. Going on the info above, I measured the depth of the hole, and the amount of thread on the bolt on backside of tensioner. The hole is about, 1 in and I'm getting 7/16th when bolt is thru tensioner. It is an aftermarket tensioner. I took the same measurement with bolt thru tensioner with the original tensioner and I'm getting 3/4 length. So I tried the original tensioner but the bolt will not run up enough to secure the tensioner in place.
    So I'm guessing that just a longer bolt will not be good enough?
    Dec 2005
    Joisey
    252
    Well that new bolt would only cost about 50 cents, so maybe its worth a try? Another cheapo option would be QuikSteel (steel-reinforced epoxy putty) to retap the hole, other than that helicoil or similar or insert I reckon.
    DJSG3
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,471
    just use the helicoil - and be done with it -
  16. #14
    Apr 2006
    Out of my mind
    653
    Did the helicoil earlier today and so far pleased with the results.
    Thanks.
  17. Remove Advertisements
