which spark plug boots are required for STS 2001
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, which spark plug boots are required for STS 2001 in Past Cadillac Vehicle Discussion; I want to replace spark plugs and boots on my sts 2001 since car has about 110K miles and spark ...
    john19999 is offline Cadillac Owners Fanatic
    Automobile(s): Seville STS 2001, Eldorado 1997
    Jun 2008
    Chicago, IL
    391
    I want to replace spark plugs and boots on my sts 2001 since car has about 110K miles and spark plugs are original. I looked at rockautos.com and found AC delco platinum spark plugs that i will buy. It has the following 2 types of boots (spark plug boots). Both have limited life time warranty but one is $3.12 and the other $5.02 each. My question is which one is required. Any idea about the cheaper one, will that work?
    ACDELCO Part # 12163650
    BOOT,SPLG WIRE
    $3.12 $24.96 Remove Part
    ACDELCO Part # 16004 {#88862521}
    BOOT KIT,SPLG 4 DOORS
    * Stocked in outlying warehouse--shipping delayed up to 1 business day
    $5.02 $40.16
    Thanks
    John
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Re: which spark plug boots are required for seville sts 2001
    Quote Originally Posted by john19999 View Post
    BOOT,SPLG WIRE
    $5.02 $40.16
    Thanks
    John
    there is only one spark plug to consider -
    ACDelco 41-987 - RockAuto has them for $36.40 + $5.50 shipping -
    PLUS - there is a $12 rebate -
    here is the form to fill out -
    http://www.acdelco.com/pdf/Spark%20P...ate%20form.pdf
    there is absolutely nothing wrong with the ACDELCO 12163650 boots -
    $3.12 each + $5.55 - shipping = $30.51 - from rockauto -
    Jun 2008
    Chicago, IL
    391
    Re: which spark plug boots are required for STS 2001
    Thank you Basscatt. I am going to order today
    Thanks
    John
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,910
    here's what you'll be looking at ...........
    Jun 2008
    Chicago, IL
    391
    Thank you Submariner409. You are always so kind in sharing info.
    Thanks
    John
    Jun 2008
    Chicago, IL
    391
    I am working on replacing spark plugs on my sts 2001. It seems that there are 8 nuts (10mm) to be removed on the front side of car to access the spark plugs. Once I remove these 8 screws, I believe there should be some T nuts. Does anyone know what is the size of these nuts so that I can get the tool to open these nuts.
    Thanks
    John
    Feb 2006
    55,910
    No T-nuts. Are you mistaking the spark plug connector boots (4 in each bank) for a T-nut ??? The black things in my picture ???? They're rubber insulated tubes with spring inner conductors - they link the cassette coil tower to the spark plug.
    You'll need a long socket extension to get down past the right bank (rear) coil cassette to remove the two 10mm nuts that secure the AIR valve flex pipe flange to the exhaust manifold - DO NOT attempt to bend that steel "flex pipe".
    Jun 2008
    Chicago, IL
    391
    I have replaced spark plugs and boots with AC delco. The car STS 2001 feels a lot more powerful. The original spark plugs on car were from Denso. So could be these original from factory. I noticed that 3 cyliders (one on front and 2 on rear) had some oil in it. The oil quantity seemed like a tea spoon size. Is it normal to have oil there or does it indicate the end of engine life. The car runs great now. It was running ok before changing spark plugs. Any ideas about this oil leakage to spark plugs please?
    Thanks
    John
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Thanks
    John
    not unusual - and nothing to be concerned about -
    68
    81,926
    It's nothing more than a leaky O ring seal in the cam cover plug well.
    Feb 2006
    55,910
    Some oil in a plug well after all that time is fairly normal and expected. The cam (valve) covers wells are sealed with O-rings at the head surface. Over time those O-rings may weep - and there's a LOT of oil flying around inside those covers. Not to worry.
    Our original plugs were DENSO - look in your owner's manual for the number and cross that with the DENSO part list - and the plugs you bought are also DENSO - under contract to GM/AC Delco. Notice the "Made in Japan" on the boxes ? Same plug.
    Jun 2008
    Chicago, IL
    391
    Thank you all - Basscat, Ranger, and Submariner409
    John
  15. Remove Advertisements
