Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: After ignition key is removed and door opened radio continuos on and power windows
  1. #16
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: After ignition key is removed and door opened radio continuos on and power window
    Backup relay in located on the relay clusters (I believe cluster no 2) on the electronics bay. Basically is one of the relays behind the rear seat backrest. The door sill thing is a circuit breaker (just 2 wires attached). A relay will have a minimum of 4 wires attached (2 for controls and minimum 2 for the contacts).
    You really need a FSM, can't fix anything withouth the schematics.
  2. #17
    thu's Avatar
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    Yes, you should get the FSM from http://www.helminc.com
    It will pay for itself the first time you have to use it for a repair.
    I just checked eBay and there are several sets for sale.
  3. #18
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    450
    I have a 2k eldo and had a similar problem couldnt figure it out untill I found one found one of the relays warm after the car hadnt been driven in days. Turns out it looked good on the out side but was totally corroded on the inside keeping power on. Had a similar problem with my headllights turning on by themselves corroded headlight relay.
    i imagine you battery runs down to.
  • You may not post replies
