5W-50 oil in 500 CI (1970 Eldorado) ?
Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
Like Tree3Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 5W-50 oil in 500 CI (1970 Eldorado) ? in Past Cadillac Vehicle Discussion; Is it advisable to use 5W-50 in a 500 CI motor? Motorcraft makes one. The original manual for the 1970 ...
    sgc2c's Avatar
    sgc2c is offline Cadillac Owners Member
    Automobile(s): 1989 Brougham d'Elegance | 1985 Seville HT4100 | 2005 Lincoln Town Car Signature Ltd
    Jan 2008
    Boca Raton FL
    72
    The original manual for the 1970 Eldorado claims
    a wide variety of oils from 5W-20 up to 20W-40
    can be used. Engine has 63,000 miles on and it,
    understandably, leaks basically every fluid you
    can put in it.
    can
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Well according to the range listed in the owners manual, 5W-50 is too thick at operating temperature. Use whatever viscosity is recommended for your local climate.
    69
    82,396
    Re: 5W-50 oil in 500 CI (1970 Eldorado) ?
    I would say 5W50 is TOO low on the low end and TOO high on the high end. I'd stick with 10W30 or 10W40, preferably 10W30.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,174
    Many large displacement gasoline engines, particularly flat-tappet cammed engines subjected to heavy duty use, successfully run a "fleet" oil such as Pennzoil LongLife 15W-40.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    5W-50 is a 50 weight oil that flows like a 5 weight oil when cold. W is for winter, which you will never see in FL.
    I always used & will always use 20W-50 in my Olds 455.
    Feb 2006
    57,174
    Why 20W-50 ?
    We use exclusively 15W-40 in these Olds 455's and GM 454's in extreme duty boat applications and have not had any sort of lube oil problems. We run Melling HD pumps at 60 psi, oil temp 210 degrees, Fram HP-2 filters, roller tip rockers, flat tappet cams (Engle).
    20W-50 is a motorcycle (air cooled) lubricant - not even recommended by Caterpillar or Cummins for diesel service.
    Feb 2012
    NYC
    50
    1,948
    True, it is considered a motorcycle oil, but as far as I've always heard it's also a racing oil.
    Works for me. Bottom end has been in the car for 10+ years with approx 600HP & lbs.ft.
    I also run an Engle (solid) cam w/Erson Pontiac roller rockers (1.65 vs 1.6) & fully ported C heads.
    I also got better results from a single plain Torker.
    I have noticed Rotella 15w40 seems thicker while pouring out of the bottle than 20w50. Imagination?
    Feb 2006
    57,174
    Darned if I know - both Rotella and LongLife (both 15W-40) are spec'd as a fleet (gasoline), diesel and marine oil. It carries a pretty heavy ZDDP load, so you don't want to run it in a cat car. I run either about 100 hours in boat engines before change - that's equivalent to 6,000 to 7,000 miles of car service. The local Western Auto carries it in 5 quart jugs and 5 gallon pails. I get the HP-2 filters in bulk from Fram.
    My Olds engines use the Milodon 8 quart pans with windage tray and I rig a remote oil change line from the (permanently installed) oil drain plug - a HD length of flex oil line to a ball valve with hose barb. Oil change time comes, warm up the oil, open the ball valve, connect a drill pump, and pump it all into a big bucket.
    Here's a pic of an HP-2 compared to a 51522 ........... The HP-2 holds just about one quart of oil and has a case burst strength of 250 psi. Anti-drainback.
    Here's a trick for your next 455 - The snaky cover over the cam in the valley. Clean it well and drop it in place. Mark the center of each lobe with a magic marker dot. Now drill a 3/32" hole at each dot and chamfer that with a 1/4" drill tip. That cover now catches oil drainback and drips it onto each cam lobe. Looks like a Mondello splash shield. I use the dual-plane Performer 2151 - work boats get a lot of idling time so they need some carb heat - so I drill 1/2" holes in the intake manifold gaskets at the crossover ports. The engine I posted went into my boat - notice the cylinder head color - they're Mondello street-ported Ga heads. (What valve rotators ??? )
    (Sorry for the thread hijack, but there are tidbits of good info in these posts - for ANY gearhead.)(and, FWIW, Shell Oil owns Shell, Pennzoil, and Quaker State. SOPUS - Shell Oil Products U.S. - read the labels.)
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by Submariner409 View Post
    It's back together now, but next time it's apart, I'll try it.
    sgc2c's Avatar
    Jan 2008
    Boca Raton FL
    72
    Back to my original question, is 5W-50 too
    extreme for Florida? I'd think the 50 weight
    would be ideal in the heat for such a large
    engine and the 5 weight is already approved
    in the manual, ideal for cold starts, however
    few those are here.
    If you favor 10W-40 or 10W-30 then which,
    and why?
    Feb 2006
    57,174
    What makes you think that the internal engine temperature - the parts not cooled by coolant: the parts cooled by oil - will be any higher in Florida than in anywhere else on earth ?? Just because the engine is of large displacement does not mean that it needs "thicker" oils.
    There is absolutely no need to run a 50 weight oil, regardless of leaks. If you're antsy for some reason that a -20 or -30 oil is not "oily" enough, then run 10W-40 or maybe a 15W-40.
    It's a 44 year old engine with no mileage - it isn't even broken in yet. Why force the bearings to wear out to clearances wide enough to accommodate a 50 weight ? 63,000 miles comes out to < 1500 miles per year. The engine doesn't even know how to run !
    Feb 2012
    NYC
    50
    1,948
    Yeah, 10 or 15w 40 will be fine.
    Not that I believe the 5w50 would do any harm though.
    69
    82,396
    Quote Originally Posted by sgc2c View Post
    If you favor 10W-40 or 10W-30 then which, and why?
    10W30 gets my vote. Should be fine for Fla. I don't like 10W40. I used that stuff back in the '80's and had to replace 2 lifters and a cam on a 302 Ford. "Sludge" wouldn't describe it. I had to scrap the oil out of the valve covers and the timing chain cover with a putty knife. I still have a bad taste left in my mouth from that. Never saw anything like it, before or since. I know oils are much better now, but I just can't bring myself to even consider using it.
    Oh, and before anyone asks, the oil was changed every 3K from day one.
  16. #14
    Feb 2012
    NYC
    50
    1,948
    I saw lots of sludgy engines in the 80's. Was it the thickness or the quality?
  17. #15
    Feb 2006
    57,174
    80's engines ? Neglect.......... of either oil changes or the PCV system .............. and some of the Japanese product had LOUSY PCV systems. Back in the Dark Ages engines were internally vented by a "road draft tube" which simply dripped oil vapor from the crankcase out onto the road - the reason that all roads used to have a black stripe down the center of each lane. Advances in PCV changed all that - and removed most of the causes of "sludge": crankcase moisture.
    If oil "thickness" had anything to do with "sludge", what would the inside of an aircraft recip engine - running 50, 60, or 80 single grade - look like ??? Or the inside of a 35,000 hp marine diesel engine, max rpm of 120, running 80W oil ???
  18. Remove Advertisements
