Another Caddy In The Stable - Page 7
Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 113
Like Tree15Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Another Caddy In The Stable in Past Cadillac Vehicle Discussion; I can hear both mine vent quite clearly, an air coming out of balloon sound almost. Kid calls it a ...
  1. #91
    rodnok01's Avatar
    Feb 2012
    NC
    6,624
    Re: Another Caddy In The Stable
    I can hear both mine vent quite clearly, an air coming out of balloon sound almost. Kid calls it a car fart...
  2. #92
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I can't really hear mine vent. AC Delco compressor assembly, several months old.
  3. #93
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,830
    I can hear mine, but it's not loud by any means - a low, low sssssssssssss.
  5. #94
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    Quote Originally Posted by Submariner409 View Post
    Same
  6. #95
    68
    81,883
    Hmm, so we have a definite maybe.
    As for curb height, I reached in on top of the tire and pulled the air line off the shock to vent it. Got a reading of 28" from the ground to the wheel well. Turned the key on, let the compressor run til it stopped and got a reading of 29 1/2" (with about 1/2 tank of gas). Anyone got a comparison reading.
  7. #96
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,871
    Just drive the damn thing :-p
  8. #97
    68
    81,883
    Will do. Thank you.
    vincentm likes this.
  9. #98
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,340
    mine sits at 28 1/2" -
    I wanted to try to get it to sit lower - here is what I did/found -
    the system maintains a minimum of 14 PSI in the air shocks -
    and THIS is what controls the total "empty" ride height -
    with the air bladders completely empty - mine sits at 28 -
    with the compressor connected it bumps it up to 29 -
    there IS a slight adjustment at the level switch - I adjusted it to the MAX UP setting -
    that dropped it to 28 1/2 -
    I made a connecting rod 1" longer - that didn't help lower the rear at all -
    there just isn't any around that 14 PSI minimum -
  10. #99
    68
    81,883
    Exactly what I was looking for Bass. Thank you. I'll look at that adjustment when I get it in the air. That's info I was unaware of.
  11. #100
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,340
    when you look at the switch - there is a 10mm bolt at the center of the lever -
    loosen it - then you want to slide the lever so it pushes UP on the connecting rod -
    you'll only get 1/4 inch of movement -
    but like I said - beyond that small adjustment -
    "empty" ride height can't get any lower -
  12. #101
    68
    81,883
    Cool. Thanks again. Based on that 1/4" adjustment the empty ride height should be 28" and that looked perfect to me after I bled the system and it sat empty.
  13. #102
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,340
    I too would have been happier at 28 -
    but with that 14 PSI minimum in the air shocks -
    mine only went down to 28 1/2 - with a full tank of gas -
    but an empty trunk and back seat -
  14. #103
    kingjay's Avatar
    kingjay is offline Cadillac Owners Member
    Automobile(s): 1999 Seville SLS, 2007 STS-4 V.6
    Nov 2012
    Bonita Springs, FL
    26
    72
    That is a beautiful car.
  15. #104
    68
    81,883
    Replaced the EOP switch today. Thank God for friends with lifts.
    Bass,
    The adjustment on the switch arm worked perfect. I could feel the ass end lower as soon as I turned the key on and now she sits nice and level. Took all the rake out of the rear end.
  16. #105
    Feb 2006
    55,830
    Drove about 32 miles today, 3 starts/stops. Right now the rear fenderwell height is 28.5" off the garage floor.
  17. Remove Advertisements
