1999 STS - engine cooling fans problem - Page 5
Page 5 of 5 FirstFirst 12345
Results 61 to 65 of 65
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1999 STS - engine cooling fans problem in Past Cadillac Vehicle Discussion; there must be switched ground on the 85 terminals of the relays, that's how they engage. did you check with ...
  1. #61
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    Re: 1999 STS - engine cooling fans problem
    there must be switched ground on the 85 terminals of the relays, that's how they engage. did you check with your test light at battery + and then to the 85 terminal?
    still could be a bad motor, try to swap them before throwing parts at her...
  2. #62
    palidin1029 is offline Cadillac Owners Member
    Automobile(s): 99 Seville STS
    Jul 2013
    66
    34
    I did test pin 85 on all three...no change.
    I will try to rule out the motor...
    Thanks.
  3. #63
    Jul 2012
    38
    140
    ok, would be my guess at that point...
  5. #64
    Jul 2013
    66
    34
    I was able to cross the fan wiring so that the RH fan was connected to the LH wire feed and the LH fan was connected to the RH wire feed. I also did a test to confirm good connections. Each fan went on when directly connected to battery+.
    When I put on the ac, the RH fan went on and the left one did not. This, to me, confirms that the RH fan is OK.
    So back to square zero. Because both fans go on when ECT is unplugged, yet only one goes on when ac is on, I believe one part of the system is triggered for serial mode but something else is preventing the 1st fan from taking half the voltage and passing the other half to the other fan.
  6. #65
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Unplug the driver side fan
    Clean the contacts
    Plug it back in
    Worked for me once
  7. Remove Advertisements
