95 Eldorado - Code P 056 current, car runs terrible, lurches, misses, awful
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 Eldorado - Code P 056 current, car runs terrible, lurches, misses, awful in Past Cadillac Vehicle Discussion; I could use some help here, I pulled this code using the manual method and I think this code means ...
    Rasmus Fog is offline Cadillac Owners Member
    Automobile(s): Eldorado
    Aug 2013
    3
    I could use some help here, I pulled this code using the manual method and I think this code means a sensor to the transmission input shaft is bad. My level is Jr. Woodchuck III, experienced on Corvette OBDI & II, any and all help appreciated. Low mileage Eldorado car is worth saving. Thanks
    If that sensor is the problem I have no idea where it is located so any help is appreciated twice!
    Chuck
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    Re: 95 Eldorado - Code PO56 current, car runs terrible, lurches, misses, awful
    IF it is the Input Speed Sensor (ISS), that's a $50 part buried $2,000 in labor inside the transmission. Its replacement requires transmission removal and disassembly.
    Use the link in the sticky post ^^^ "How to pull codes" to get to the code definitions for OBD1 codes.
    There are several recent threads with a diagram of all 4T80E sensors and switches - but it's a 1998 and later transmission so there are a couple of differences - but not the ISS, unfortunately. The diagram is also in my albums.
    A faulty ISS will not cause an engine miss - that's another bugaboo somewhere.
    69
    82,287
    Re: 95 Eldorado - Code P 056 current, car runs terrible, lurches, misses, awful
    Quote Originally Posted by Rasmus Fog View Post
    Chuck
    Feb 2006
    56,884
    Chuck
    The transmission is driven by an input shaft and articulated link chain, very similar to a stock timing chain setup. The ISS is inside the chain run loop with it's Hall effect end in extremely close proximity to the input gear teeth.
    It is used by the PCM/ECM to correlate engine input shaft speed with transmision load, gear, and shift functions.
    Aug 2013
    3
    Thanks guys for your info & advice, I understand, P056 is not good news. Is there anything else I should know about that would cause that code in error? I suspect the value of this vehicle just took a nose dive. Anything else?
    Aug 2013
    3
    Vehicle was towed to local mechanic shop, he replace a couple of coil packs and the TPS. Engine runs good now and vehicle can be driven. Price was reasonable too. No conclusion on the 056 error code. Thanks for the input / support guys!
  9. Remove Advertisements
