Does a clamp belong on the flex duct resonator hole ? 2002 STS
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Does a clamp belong on the flex duct resonator hole ? 2002 STS in Past Cadillac Vehicle Discussion; I recently bought a 2002 STS and took the air intake assembly apart this morning to check the air filter ...
    LloydCFerguson is offline Cadillac Owners Member
    Automobile(s): 1997 ETC, 2002 STS
    Mar 2012
    Glendale, CA
    44
    I recently bought a 2002 STS and took the air intake assembly apart this morning to check the air filter and clean the throttle body (though it might improve the fuel economy a bit). When I took the upper assembly off the air intake (not sure what it does or what they call it, maybe a muffler or resonator) there was a worm clamp around the connection going to the air intake tube and it appeared that it was not put back on correctly. STS Air Intake.jpg The clamp doesn't like it belongs there or is mounted the wrong way around it almost seems that this would snap together without a clamp. Does anybody know if this is correct and/or which way the clamp should be oriented.
    Thanks in advance.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,267
    Re: Does Clamp Belong on Uppoer Air Box Assembly
    That hole is for the intake resonator assembly. The engine will not run correctly with that hole open or not properly clamped due to the divorced MAF next to it.
    Go to a hardware store and find a 2" pipe cap or a proper sized PVC pipe cap and clamp it in the hole - discard the resonator and use a suitable machine screw in place of the Torx screw in the top of the PCM box cover.
    Pictures of this in my albums - The Community tab, Albums, the red Seville. 2 albums, 6 pages of stuff for your car.
    The original factory clamp on that hole neck was a non-adjustable spring clamp - most of them have been replaced by your band clamp. I discarded my reasonator 7 years ago and have never regretted it - it sure makes engine and parts checks a whole lot easier.
    FYI, The transmission is a dry sump unit - there should be NO FLUID on the transmission black plastic dipstick with the engine off. Check level with the engine hot (> 10 mile run) idling in P on a level surface. That little metal wiggle cap and hose clipped to the throttle cable bracket is the transmission vent hose.
    What is the build date on the sticker on the driver's door edge ???
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The part you removed is the resonator. It quiets induction noises (though mine is removed, and I hear essentially no difference).
    The factory clamp is one time use. A hose clamp is too wide, and the resonator will not sit right, and eventually falls out.
    Best thing to do would be to leave the resonator off, and plug the hole - The "butt plug mod".
    It makes air filter changes and trans fluid level checks much easier, and you don't have to worry about it coming loose and causing a vacuum leak.
    Oops, sub beat me.
    Mar 2012
    Glendale, CA
    44
    Thanks for the quick reply! I think I have the resonator back on correctly now, the last person didn't screw in the Torx head stud that the resonator slips over, once I corrected that the resonator lined up perfectly with the hole in the intake tube. I couldn't find a good position for the clamp where I could loosen it with a screwdriver so i used a ratchet. I'll probably take it apart again next weekend to check the transmission level as you suggested.
    My build date is 11/01.
    Sep 2010
    East Boston MA.
    29
    26,325
    Problem is, the engine has to be running to check the transmission fluid level.
    Feb 2006
    56,267
    Re: Does a clamp belong on the flex duct resonator hole ? 2002 STS
    11/01 = CVRSS STS. (F45 active suspension, FE3 spring package.)
    When you go through the drill to check transmision fluid level, stuff a rattle can paint cap in the open resonator hole so the engine will run/idle correctly.
    Sep 2010
    East Boston MA.
    29
    26,325
    I used a PVC pipe cap, painted black.
    divine97godly's Avatar
    divine97godly is offline Cadillac Owners Member
    Automobile(s): 99 Sts
    Mar 2012
    Charleston, Sc
    47
    Does it have to be a PVC pipe cap I just replace the resonator with a rubber material cap?
    68
    82,081
    Any cap that will plug the hole will work.
    Same here. Just did that to my daughters car. Looks like it came from the factory that way.
  12. Remove Advertisements
