'01 Eldroado Keyless entry Issues
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, '01 Eldroado Keyless entry Issues in Past Cadillac Vehicle Discussion; Hello to everyone- Brand new to the forum, and this is my first newer Cadillac. Its a 2001 Eldorado ETC ...
    andydale is offline Cadillac Owners Member
    Automobile(s): 2001 Eldorado ETC
    Jul 2013
    42
    8
    Question'01 Eldroado Keyless entry Issues
    Hello to everyone-
    Its a 2001 Eldorado ETC w/ only 17k on the clock.
    Still has new car smell in it, which I LOVE!
    I haven't posted any pictures yet. I am planning to do so soon.
    Here is what I have going on:
    When I got the car, it didn't come w/ any keyfobs. So, I purchased one off Ebay, I have the correct part number, as I got it from the dealer. I took the car and the fob to the dealer to program as apparently you cannot do it w/o a tech II programmer.
    The first fob they couldn't program as they said the fob is not working. So I purchase a new fob from them.
    Took the car back today w/ the new fob and they still cannot get it programmed, and now they say the RFA unit is faulty, and they want to take apart the drivers door panel to check and test the module.
    I stopped them their as it seemed flaky that the device would be located in the door, when every other car I have worked on the device is located in the trunk on the package shelf underside.
    So what I am looking for is the definite location of the RFA unit, and any other troubleshooting tips anyone might have.
    I am already tired of spending money at the dealer to get the run around.
    Thanks!
    Andy
    Sep 2003
    Metro ATL
    4,854
    Re: '01 Eldroado Keyless entry Issues
    Quote Originally Posted by andydale View Post
    ....So, I purchased one off Ebay, I have the correct part number, as I got it from the dealer. I took the car and the fob to the dealer to program....
    Do you see the common thread running through here?
    It sounds like you are hooked up with a service advisor and a technician both of which have no experience with your year/model vehicle. I will stop short of bad-mouthing all dealership service department employees as that would not be fair to the cashiers.
    There is some terminology confusion here. The term RFA (Remote Function Actuator) was not used in your year/model. GM starting calling it the RCDLR (Remote Control Door Lock Receiver) at some point.
    And your RCDLR is located on the electronics panel at the rear surface of the bulkhead between the trunk and the back of the rear seat. Accessible from the trunk. The RCDLR has a four pin connector.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    the RCDLR (remote control door lock receiver) is mounted on the back of the back seat under the package shelf with a bunch of other modules
    not sure exactly where the RFA is since i'm pretty sure it's part of either the BCM or the RCDLR ... but both of those are in the same area
    there was something in the door related to keyless remotes but i can't seem to find anything in my parts catalog right now
    check this thread for info on helping yourself
    http://www.cadillacforums.com/forums...entry-fob.html
    ok so JimD cleared up that terminology mix-up ... thanks Jim!
    Jul 2013
    42
    8
    Rippy-
    Thanks for the link, I had tried all of these tricks and things before posting, none of which worked on my car. I am going to pull the trunk apart tonight and look for the RCDLR in the trunk per JimD's post.
    I might be looking you up for parts if needed, I feel like the dealership here is a bunch of idiots! I will not tell you what they charged me for the 2nd remote.
    Andy
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    The cover to the housing for the RCDLR will need a deep 10mm socket, two up top on each side for the rear seat and two down below on the left and right, then it will fold down towards you. Pull the top trunk liner (not the lid) first to reveal the cover
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    If they want to remove the door panel to get to the RFA then find another dealership. As everybody mentioned the module is accessible from the trunk from inside the car after removing the rear seat back rest.
    '98+ cars do require TechII for programming the remotes.
    If you can find a RFA with its remotes you can just swap the module and use the remotes w/o the need of reprogramming (thus no need of TechII)
    Sep 2007
    Wilmington, NC
    13,986
    #8 is your RCDLR
    (note the FWD arrow below the module for spacial reference)
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Your RFA module is located in the same spot but is gray and smaller than pictured.
    In case you don’t understand the picture, is what you see after removing the rear seat back cover and the trunk liner and dropped down the plastic cover behind the rear sear back rest. That plastic cover is actually a tray where all the electronics modules are located. It is what we call “the electronics bay”
    Jul 2013
    42
    8
    Good Morning...
    I thought I would let everyone know that I finally was able to get and install and have programmed (at a different dealer, Chevrolet HAHAHA!) the RCDLR in the trunk and now have two working key fobs!!!
  12. Remove Advertisements
