85 Eldo Telescopic wont tighten or lock
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 85 Eldo Telescopic wont tighten or lock in Past Cadillac Vehicle Discussion; I replaced the worn steering wheel on my 1985 Eldorado Biarritz Convertible with a better one. Seemed pretty simple until ...
    XTNCT is offline Cadillac Owners Member
    Automobile(s): 84 & 85 ELDORADO CONV / 79 SEVILLE
    Jul 2013
    1
    Post85 Eldo Telescopic wont tighten or lock
    Seemed pretty simple until attempting to reinstall.
    I aligned the wheel to the shaft replaced the spring and the rubber (hose) grommet then the telescopic lock assembly with the three bolts.
    Now the wheel moves freely in and out no matter how tight I try to tighten the telescopic lock.
    I have found exploded diagrams and all looks to be correct.
    Can anyone help? Thanks
    Feb 2003
    california
    69
    6,639
    Re: 85 Eldo Telescopic wont tighten or lock
    Remove the horn pad again then remove the 3 screws holding the lock lever and remove it. Now turn the threaded shaft by hand clockwise to lock the wheel. Then reinstall the lock lever and 3 screws in the middle of the slots with the lever to the right of the steering wheel slot. The lever only has to move a quarter inch left to release the shaft. You simply did not thread the shaft far enough into the column.
    flacko93 is offline Cadillac Owners Member
    May 2006
    35
    How many miles on your 85 eldo? I have one too. Mine has 58k. I love driving it! It turns so many heads both young and old. And mine has an awesome horn!!
