A/C causing Battery Voltage decrease
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, A/C causing Battery Voltage decrease in Past Cadillac Vehicle Discussion; Battery voltage reading on dash decreases drastically at stop lights with A/C on....
    roachetim is offline Cadillac Owners Member
    Automobile(s): 95 eldorado etc 03 CTS
    Jul 2013
    57
    4
    Sep 2003
    Metro ATL
    4,854
    Re: A/C causing Battery Voltage decrease
    Quote Originally Posted by roachetim View Post
    Which vehicle? Put a number value to "drastically".
    Unless your battery and charging system fail to crank the engine, maybe you could monitor something other than Volts.
    Jul 2013
    57
    4
    95 Eldorado ETC w/New Battery measures 12.8 at terminals with DC volt meter, New alternator measures 14.1 on dash upon start-up. Once A/C activated immediate Battery volt drop to 13.4, will hold till warmed up and driving, then at stop lights in drive, with brake peddle depressed, have had volt drop to 11.9, RPM steady around 700. Voltage increases if shifted to N and/or start to drive.
