2001 STS Rear 3rd Brake Light Fuse?
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 STS Rear 3rd Brake Light Fuse? in Past Cadillac Vehicle Discussion; Hi I went and bought off E Bay a Working Used 3rd. Brake Light. I though the one on the ...
    PeterS is offline Cadillac Owners Member
    Automobile(s): 2001 (Seville) STS
    Feb 2008
    Staten Island,Ny 10309
    59
    81
    Smile2001 STS Rear 3rd Brake Light Fuse?
    Hi
    I though the one on the was Broken.
    But when I Disconnect the Light install on the Trunk Now and Put 12volts to the Light it Works.
    But No Volts coming into the Connector when I but my foot on the Brake.
    Is there a Fuse Just For this Light?
    Thank You For Your Help.
    Pete
    Sep 2003
    Metro ATL
    4,854
    Re: 2001 STS Rear 3rd Brake Light Fuse?
    Quote Originally Posted by PeterS View Post
    No. The same fuse protects all three stoplamps. Do your fender mounted stoplamps work?
    If yes, you will have to use your voltmeter to chase that white wire and black wire pair for the trunk mounted stoplamp backward until you locate a damaged/broken wire.
    Feb 2008
    59
    81
    Hello
    Thank You.
    The Black and white wire is taped together. I will have to un tape them and follow them.
    Thanks Again.
    Pete
    SwampeastMike is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS, White Diamond
    Nov 2008
    Cape Girardeau, Missouri
    53
    782
    Check for a broken wire in the harness leading to the trunk lid. It comes through on the driver side near the hinge. Lots of movement there and the wires have been known to break.
    Feb 2008
    59
    81
    Hi
    Great! I will check it out.
    Great Start!
    Pete
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,821
    ......... also check the wiring harness grounds at the left rear fenderwell body metal - under the trunk carpet.
    https://www.google.com/search?q=cadi...ient=firefox-a
    Feb 2008
    59
    81
    Hi
    Thank You .
    Will Check when I get Back From Vacation.
  10. Remove Advertisements
