POP, pshhhhhhhhhWhoooosh is what came out of my A/C lines somewhere while I was - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Like Tree4Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, POP, pshhhhhhhhhWhoooosh is what came out of my A/C lines somewhere while I was in Past Cadillac Vehicle Discussion; UPDATE- - I had a gauge hooked up to the low side. the ones that hook straight to a can ...
  1. #31
    69
    82,382
    Re: POP, pshhhhhhhhhWhoooosh is what came out of my A/C lines somewhere while I was
    UPDATE- - I had a gauge hooked up to the low side. the ones that hook straight to a can of Freon with a trigger. there was no can hooked to it because I was only checking pressure. My friend who was (helping me) was holding the gauge and pulled the trigger two times and I heard the rush of air.
    So I am wondering - Did Freon come out or did outside air go in????
    It came out. Throw that damned thing away and get a real set of A/C gauges.
    UPDATE - after installing 48oz of Freon and 3oz oil the low pressure seems to hold at 47-48psi when idling and drops to 43-44 when revved to 2000rpm then back up at idle.
    Your low side pressures are too high.
    So if I have 48oz Freon in (my dryer says 2lbs on the label) then it must be full so what else can I check
    48oz = 3 lbs. You are overfilled.
    high pressure around 200psi.
    How do you know that? You can't check the high side pressure with that Mickey Mouse gauge.
  2. #32
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,850
    CONGRATULATIONS -
    you have successfully over-pressured the system - AGAIN -
    and the LOW side pressure is TOO HIGH -
    and how did you come up with that IMPOSSIBLE number -
    squeeze the high pressure line - and guess?
    go back and re-read #26 - then do what it says -
    report back with the actual pressure readings -
    from a real set of AC gauges -
    Aztec ETC ECS likes this.
  3. #33
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by basscatt View Post
    CONGRATULATIONS -
    ^You beat me to it.
    Why would you possibly put in 48oz where 2lbs should be? Why??
    More does not make it colder!
    Also, too much oil can not only cause low side pressure to be too high but hydro the compressor.
    basscatt likes this.
  5. #34
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Take it to someone who knows what they are doing before you ruin the whole system.
    basscatt and 98cadillac like this.
  6. #35
    Feb 2012
    NYC
    50
    1,948
    Or at least use a calculator.
  7. Remove Advertisements
