POP, pshhhhhhhhhWhoooosh is what came out of my A/C lines somewhere while I was - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 35
Like Tree4Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, POP, pshhhhhhhhhWhoooosh is what came out of my A/C lines somewhere while I was in Past Cadillac Vehicle Discussion; UPDATE- After vacuum and then installing one 3oz can oil and two and a half 12oz cans of Freon the ...
  1. #16
    eldoradojoe is offline Cadillac Owners Member
    Automobile(s): 98 eldorado
    Jul 2013
    13
    Re: POP, pshhhhhhhhhWhoooosh is what came out of my A/C lines somewhere while I was
    UPDATE-
    After vacuum and then installing one 3oz can oil and two and a half 12oz cans of Freon the compressor does not come on without jumping it. My current pressures with a/c on but no compressor engaged are high side 125 and low side about 135. codes that come up are ACM B1348 and PZM B 2470
    I was adding Freon before all this happened because the computer said (low refrigerant) .
    Right now if you jump the compressor the readings are High 250 and Low 47. when the dash lights up (a/c off low refrigerant) the high and low start to rise even though the compressor is still jumped on....
  2. #17
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    Quote Originally Posted by eldoradojoe View Post
    UPDATE-
    that is STATIC PRESSURE - and means NOTHING -
    other than there is some amount of freon in the system -
    as Ranger said - you should NOT need to jumper anything
    to have the AC work -
    however - the compressor WILL NOT engage
    IF there is a low pressure fault code -
    if you were - and are still getting a LOW REFRIGERANT code -
    and with the use of ACCURATE pressure gauges
    you have determined that the refrigerant is NOT low -
    you MUST have a defective LOW PRESSURE SWITCH -
    unless the ambient temperature is close to 100* -
    BOTH HIGH and LOW pressure readings are too high -
    what is the outside - ambient - air temperature -
    what is the temperature of the discharge air -
    at the center vent -
    with temp set to 60* -
    and blower on a medium speed -
  3. #18
    Jul 2013
    13
    Temp outside is a blistering Texas 100 degrees.
    With the compressor jumped the air at the vent is good and cold
    where is the low pressure switch located?? I will go buy one and replace it
  5. #19
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    well - in that case - your pressures are right on the money -
    real close to the low side service port -
    ACDELCO 152876
  6. #20
    69
    82,262
    UPDATE-
    With no compressor running the static pressures should be the same. That said, those are too high. I think a fully charged system has around 70 psi static pressure on both sides.
    Low side seems rather high.
    #4
    http://www.gmpartsgiant.com/Page_Pro...X=2&SortKey=30
  7. #21
    Jul 2013
    13
    Basscatt and Ranger, thanks for your help.
    I will pick up a low pressure switch tomorrow and see what happens.....
    Hey Basscatt, different subject,,
    My roommate has a 95 Eldorado and just replaced the struts and shocks. they are aftermarket but said to install and plug right in like the originals. Well after a month these baby's are still a rock solid ride, it is horrible!! Is there any way to ease up on the air pressure or something to make the ride softer??
  8. #22
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Yea, get OEM $hock$ and $trut$
  9. #23
    69
    82,262
    Nope, It's the nature of the beast.
  10. #24
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    let me guess - he got arnott - or gabriel - or something other than Monroe -
    unfortunately - that's probably how it's going to ride -
    UNLESS the rear ELC is malfunctioning -
    and have inflated the rear shocks and won't deflate them -
    you can easily tell if the rear end is sticking up really high -
    or the struts/shocks are defective -
    what brand did he get?
  11. #25
    Jul 2013
    13
    OK so I installed a new low pressure switch and the a/c came right on and blew cold for a minute then went warm for a min then cold then warm..... it seems the compressor is going on and off...
    I checked and the high side is about 49psi with temp at 100 degrees here. I cant believe it needs more Freon with three 12oz cans and one 3oz can of oil in there now... so maybe too much????
    I don't know the low side reading cause had to give back the gages but when you turn a/c off high side goes to 105psi
  12. #26
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    DO NOT ADD ANYTHING WITHOUT KNOWING WHAT THE PRESSURES ARE -
    you probably mean LOW SIDE -
    and 49 on the LOW SIDE is actually pretty high -
    even taking into account ambient temp of 100* -
    the compressor is CYCLING for a reason -
    now we have to figure out WHY -
    YES - if the system was LOW on freon -
    the compressor would cycle - to protect the compressor -
    freon carries the oil to lubricate the compressor pistons -
    lack of oil will destroy the compressor -
    likewise - if the HIGH SIDE pressure was too high -
    the compressor would cycle - to protect the system -
    likewise there are freon temperature sensors in the system -
    if the liquid freon gets too hot - it can't transfer heat -
    so the system shuts down the compressor so the liquid freon can cool off -
    check for codes -
    connect a FULL SET OF GAUGES -
    we need BOTH HIGH AND LOW readings -
    HIGH pressure switch is #29 on Ranger's illustration -
    Refrigerant Temperature sensor is #14 -
    if either of these switches are bad - it could cause the cycling -
    DO NOT JUMP - OR BYPASS ANY SAFETY SWITCHES -
    TO FORCE THE COMPRESSOR TO ENGAGE -
    YOU WILL DAMAGE SOMETHING -
  13. #27
    69
    82,262
    Volume wise you are right where you should be.
    The system holds 2.2 lbs. (35.2 oz.)
    You put in three 12 oz. cans (36 oz.)
  14. #28
    Jul 2013
    13
    UPDATE - after installing 48oz of Freon and 3oz oil the low pressure seems to hold at 47-48psi when idling and drops to 43-44 when revved to 2000rpm then back up at idle. its about 100 degrees outside. high pressure around 200psi. I replaced the low pressure switch which did fix the compressor to come on but it is still cycling on and off like 1 minute on and 2 min off and repeat. So if I have 48oz Freon in (my dryer says 2lbs on the label) then it must be full so what else can I check
  15. #29
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    go back and read #26 -
    and recheck for codes -
  16. #30
    Jul 2013
    13
    UPDATE- - I had a gauge hooked up to the low side. the ones that hook straight to a can of Freon with a trigger. there was no can hooked to it because I was only checking pressure. My friend who was (helping me) was holding the gauge and pulled the trigger two times and I heard the rush of air.
    So I am wondering - Did Freon come out or did outside air go in????
  17. Remove Advertisements
